Home > Forums > Software User Forums > FLOW-3D
Vacuum Initial condiction
Old   March 11, 2010, 07:46
Default Vacuum Initial condiction
liang liam
club68512 is on a distinguished road
hello, every one
i have a problem
does the Initial condiction can set Vacuum ?
thanks
club68512 is offline   Reply With Quote
Old   March 12, 2010, 00:04
michael barkhudarov
MuxaB is on a distinguished road
voids can be assigned pressure and temperature, but without the use of a bubble model it does not make much difference for one-fluid incompressible flow. What is the application you are using it for?
MuxaB is offline   Reply With Quote
Old   March 12, 2010, 02:07
liang liam
so the voids is air?
I don't know the void means,and how to use it.
i wanna use vapor started into a tube to condensation and I think the tube should not have any fluids at first. so i wanna set the tube as vacuum condiction at first.
thank you very much! you really help me many times!
Old   April 6, 2010, 10:20
michael barkhudarov
If you want to inject vapor into a vacuum, then a void model will not work. You will need to use the two-fluid model, with fluid #1 representing liquid phase and fluid #2 representing the vapor. The initial vacuum will have to approximated by the vapor at a low density.
You can then inject vapor (fluid #2) at a mesh boundary by specifying the velocity, density and temperature at it. As it condenses it will form fluid #1, liquid that is..
Old   April 6, 2010, 10:32
liang liam
thank you for your reply!
The initial vacuum will have to approximated by the vapor at a low density. I don't know that means??...
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
