Home > Forums > Software User Forums > FLOW-3D
simulation problem
Old   April 9, 2010, 02:37
Default simulation problem
bojiezhang
bojiezhang is on a distinguished road
Preprocessor Messages:
** warning - surface area for **
** component 1 is zero **
open area mismatch at inter-block boundaries of all blocks
as % of total open area at these mesh boundaries = 8.55612E-11
hello everyone!I have a question about simulation.
first,I do not know what mean for "warning - surface area for component 1 is zero".I set component 1 as a porous component.second ,I have set inter-block by fixed point,why it tells me "open area mismatch ".
so I want to ask if they affact the result and how to solve them?thank you!
bojiezhang is offline   Reply With Quote
Old   April 9, 2010, 05:47
YongDazztech
yong is on a distinguished road
you should refer this to your respective support in your country.
yong is offline   Reply With Quote
Old   April 10, 2010, 13:13
Yang Yue
therockyy is on a distinguished road
For porous media, when you click "porous properties" under component 1, there will be a list of variables including porosity, X/Y/Z-direction porosity, etc. There is also one blank named "Specific surface area", which has a default value of 0.0. That's the reason why the processor give you such a kind of warning. It won't affect the result.
The open area mismatch like yours won't affect the result either. But try to re-mesh the region will be better. Use uniform mesh size for all mesh blocks or try different mesh size will solve the problem.
Yang
therockyy is offline   Reply With Quote
Old   April 10, 2010, 23:08
bojiezhang
Yang
Thank you for your help! But when I try to mesh by cell size or the number of celll,the sofeware will adjust it automatically,so the cell size will become different from what I have meshed.
And the cell of inter-bolck is smaller than the out-block,so they are just connected with some nodes,is it the probem ?
Old   April 11, 2010, 10:00
Yang Yue
Yes, it is a problem. The way I solved this is trying to carefully choose the coordinators of x,y and z direction of the mesh blocks, then choose the appropriate mesh size to make sure the dimension of the mesh block could be divided by the mesh size without remainder. For instance, if I mesh one component in a mesh block with the coordinators of 50mm, 20mm and 10 in 3D, I 'll only choose the mesh cell with size of 5mm, 2mm or even smaller.
When there are two mesh blocks with different mesh size adjacent to each other, I'll try to make sure that the mesh size of one mesh block is the multiply of the other's, like 4mm adhere to 2mm. In this condition, at least nodes of one block will exactly connect with the other one. So, the mismatch is minimized and will keep the influence on the result to a very low level.
My methods sound quite easy but straightforward. I hope it can help you.
Yang
Old   April 14, 2010, 08:45
bojiezhang
Yang
Thank you very much!I think it is a good idea,and I wil try it later!
problem in tornado simulation with FLUENT, please help Kestas FLUENT 10 April 25, 2012 06:20
Problem restarting a simulation from an intermediate point. sergiorbrett CFX 2 April 21, 2010 17:11
problem of river flow simulation Liu Main CFD Forum 0 May 27, 2004 22:01
2D simulation as boundary condition for 3D problem Jan De smet FLUENT 1 October 11, 2002 02:02
simulation of incineration problem xinxin Main CFD Forum 1 November 27, 1999 16:34
