Home > Forums > Software User Forums > FLOW-3D
Contours of 2D plotting
Old   April 12, 2010, 10:15
Default Contours of 2D plotting
Yang Yue
therockyy is on a distinguished road
Hello fellas,
I have a question about the result plotting in 2D.
I've chosen NF value as the contour variable and contour type is colour shaded. The snapshots of the ploted result have white lines indicate the free surface of the fluid (I guess) as showed in the attachments. The blue grids repersent the flow while the red grids are voids.
Since the deep blue grids do not have free surface, if the white line shows the free surface, it should be above the blue grids. This doesn't correspond to the plotting results. However, the white line shows a more realistic free surface of the flow in the attachment which modelled a plunging jet.
So my question is how this white line been plotted? Which data is used to plot the white line of the free surface in 2D?
Cheers!
Yang
therockyy is offline   Reply With Quote
Old   April 14, 2010, 09:28
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by therockyy View Post
Hello fellas,
Cheers!
Yang
Yang, the white line is drawn based on the fluid fraction F. It is the contour line of F=0.5 since in the void F=0 and in the fluid bulk it is 1.
MuxaB is offline   Reply With Quote
Old   May 5, 2010, 06:50
Yang Yue
Thanks, Michael.
A quick question: Is the free surface plotted in 3D also based on the volume of fraction of the cell?
I just feel confused about the NF value and the fraction of fluid. Can I explain this like that the NF value is the flag to lable the surface cell, but the calculated free surface is plotted by fuid fraction? Is that the concept of the volume of fluid method?
Thanks a lot!
Yang
Old   May 5, 2010, 11:09
michael barkhudarov
Yang,
You are right, NF is used for labeling free surface cells, while fluid fraction is used for plotting in 2d and 3d. I am not sure the NF flag is part of every VOF method, but it is certainly useful in FLOW-3D.
Old   December 22, 2012, 15:04
Default fluid depth
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi friends,
How we could get results in post processor part for fluid depth (e.g. in a free surface modelling) along the geometery?
zandi is offline   Reply With Quote
Turbo contours Max n Min Values Sans CFX 2 May 31, 2008 04:22
Plotting Contours of Experimental Data Umm.. FLUENT 4 February 20, 2008 16:27
Preconditioning and pressure contours ganesh Main CFD Forum 2 February 18, 2006 00:02
extension for liquid fraction contours venugopal FLUENT 0 June 11, 2004 01:27
