Home > Forums > Software User Forums > FLOW-3D
cylindrical mesh
Old   June 3, 2010, 13:07
Default cylindrical mesh
Han
alefem is on a distinguished road
When I use the cylindrical mesh, I set Y direction from 0-360, but it seems that there is a gap at the location of 0/360 degree, which can found in the attached figure after used FAVOR render. In fact the result also show there is a gap.
How can resolve this problem?
alefem is offline   Reply With Quote
Old   June 4, 2010, 00:38
ignatz is on a distinguished road
Hi Alefem,
As I recall, you are doing casting simulations...right? Not a good idea to use cylindrical meshing for that type of problem. Stick with Cartesian.
Cheers
ignatz is offline   Reply With Quote
Old   June 4, 2010, 02:03
ck5285 is on a distinguished road
Hi Cylindrical mesh is typically used for 2D-Axis-Symmetry model in order to speed up simulation time. Typical application of Cylindrical mesh is Inkjet simulation. Others than that i would recommended to use Cartesian mesh.
ck5285 is offline   Reply With Quote
Old   June 4, 2010, 02:25
Han
Hi ignatz,
Yes, I am doing casting simulation.
Usually, I would like to use Cartesian mesh, but for those cylindrical mould project, I am afraid the Cartesian mesh is hard to discribe the mould boundary, so I tried the cylindrical mesh and met this problem.
Do you have any suggestion for the cylindrical mould peoblem?
Originally Posted by ignatz View Post
Hi Alefem,
Cheers
Old   June 4, 2010, 02:35
Han
Thank you ck5285,
Am I undstand right for the following?
For those 2D-Axis-Symmetry model, we only need to simulate a slice, for exmaple 30 degree, of the whole modle, so there is no gap problem as I mentioned.
Old   June 4, 2010, 16:30
ines
noussa is on a distinguished road
hi,
i am doing a simulation of 3D problem.i want to draw it cylindrical coordinate sysyem(r,z, o).but gambit shows X , Y , Z Coordinate . how to do in cylindrical co ordinate , will it show r, z and o axis ?
i opened the Tools command button then i changed the co ordinated system to cylindrical and I acctivé it . but it still at cartesien coordinate
please reply
noussa is offline   Reply With Quote
Old   June 7, 2010, 20:56
yes you are right, so for your problem set it to 30o if it is 2D-axis-symmetry model and if not then would recommend to use Cartesian mesh. the Cylindrical mesh is not meant for you to revolve from 0o to 360o for cylindrical object. you will always faced this problem if stay with cylindrical mesh for your model. Hope this help.
Originally Posted by alefem View Post
Thank you ck5285,
CK
Old   June 7, 2010, 20:57
Hi noussa
you should submit your question in Fluent forum and not this Flow-3D forum.
Originally Posted by noussa View Post
hi,
please reply
Old   June 8, 2010, 08:07
ines
OK, thank a lot.
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
[Salome] unv mesh corrupted after createPatch maddalena OpenFOAM Meshing & Mesh Conversion 1 February 18, 2010 07:43
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Define mesh motion in cylindrical CS rikio CFX 0 June 3, 2009 22:21
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
