Home > Forums > Software User Forums > FLOW-3D
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Old   December 3, 2010, 07:23
Default forrtl: severe (174): SIGSEGV, segmentation fault occurred
Yang Yue
therockyy is on a distinguished road
Dear all,
Has anybody encountered this problem before? The entire message is :
p, li { white-space: pre-wrap; }
restart and spatial data available at t= 0.00000E+00
t cycle iter dtstbl/code delt vl epsi cpu clock
0.00E+00 0 0 3.89E-04/st 3.89E-04 4.63E-10 -1.0E+00 1.3E+01 11:37:24
Image PC Routine Line Source
libpthread.so.0 000000307790C420 Unknown Unknown Unknown
hydr3d 00000000008D5947 Unknown Unknown Unknown
libguide.so 0000002A955BFD33 Unknown Unknown Unknown
libpthread.so.0 000000307790C2BE Unknown Unknown Unknown
libguide.so 0000002A955C1941 Unknown Unknown Unknown
Abnormal exit from solver.
I've totally lost this time. It seems the error is related to some codes or the pressure boundary settings. Does someone know how to fix it?
Many thanks!
Yang
therockyy is offline   Reply With Quote
Old   December 24, 2010, 21:06
LT
NewKid is on a distinguished road
Have you figured this out?
I have encountered the almost same question.
NewKid is offline   Reply With Quote
Old   January 14, 2011, 06:08
Yang Yue
Actually, I haven't. But if you change the value of the pressure boundary, it could be fixed sometime. Good luck!
Yang
Old   January 17, 2011, 01:20
michael barkhudarov
MuxaB is on a distinguished road
Yang
What version of FLOW-3D are you running?
MuxaB is offline   Reply With Quote
Old   January 17, 2011, 06:36
Yang Yue
I just checked that. I'm using version 9.4 64-lnx 2009.
Old   January 19, 2011, 00:43
michael barkhudarov
There have been two updates since then. The latest is 9.4.2. Can you try it?
Old   January 19, 2011, 04:37
Yang Yue
Thank you very much for all your replies. I'll ask our administrator update the software. By the way, is there main changes between V9.4 and V9.4.2?
Old   January 19, 2011, 22:52
michael barkhudarov
The list of fixes comes with the update from the user site.
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Debugging a segmentation fault? hansel OpenFOAM Bugs 3 July 31, 2010 13:13
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
Arrghh!!! segmentation fault occurred july Siemens 1 April 10, 2002 06:23
