Home > Forums > Software User Forums > FLOW-3D
heat, mass flow and cooling
Old   January 11, 2011, 01:46
Default heat, mass flow and cooling
Marcin
m.malysza is on a distinguished road
So i have a casting with pipe in mold. Thru the pipe is flowing a cooling fluid. I want to analize how many fluid is needed to cool the casting to certain temperature and how fast the cast will lose it's temperature (of course that will depend on cooling media). And i want to have a closed flow, so the temperature in container with that fluid will grow. Can i model something like that.
m.malysza is offline   Reply With Quote
Old   January 12, 2011, 19:26
Daniel
Davahue is on a distinguished road
Yes, you can. Flow-3D has some Heat transfer models. There is also available some specifics models of advection for confined flow and you can also accelerate this kind of problems to steady state.
You can find examples in Flow-3D techpapers as well.
Hope it helps,
Dani
Davahue is offline   Reply With Quote
Old   January 17, 2011, 01:23
michael barkhudarov
MuxaB is on a distinguished road
To model a closed system, you could employ a periodic mesh boundary condition, in which whatever leaves at one end enters at the opposite boundary. However, without an extraction of heat form the fluid in the cooling system, it will just heat up to the temperature of the casting, eventually, wouldn't it?
MuxaB is offline   Reply With Quote
conjugated heat transfer cooling flow over fuel rods galapago FLUENT 0 July 17, 2010 03:03
Cooling Heat Flux Corentin FLUENT 0 July 25, 2008 04:31
Cooling mechanisms and inversed flow in cylindroco Andreas FLUENT 0 February 11, 2004 07:31
cooling fluid flow susan burke FLUENT 1 November 24, 2003 10:22
Airpak: Problems with heat flow contour conditions Ivan de Miguel Urain FLUENT 1 November 16, 2001 09:36
