Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
3 phase flow convergence problem
Old   June 7, 2013, 00:47
Default Multiphase convergence problem
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
Hi all,
I am working on a case study- oil , gas water separator ( 3 phase flow).
Getting convergence problem with continuity residual.
can any1 help me ?
Using pressure based , eulerian model with energy equation.
Thanks in advance
sampathevs is offline   Reply With Quote
Old   June 7, 2013, 01:51
Vignesh KPV
vigii is on a distinguished road
Send a message via Skype™ to vigii
Once check all the values that are been defined to boundary conditions.
vigii is offline   Reply With Quote
Old   June 7, 2013, 05:21
hi,
boundary conditions are fine. even I am getting the results . But residuals are not converging. All my contour plots are matching with the case study results. But how to reach the convergence ?
Old   June 7, 2013, 06:18
OJ
oj.bulmer will become famous soon enough
Have you explored if the flow is steady or transient?
OJ
oj.bulmer is offline   Reply With Quote
Old   June 7, 2013, 06:49
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Try coupled solver and reduce all relaxation factors & Courant number until solution converges.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   June 7, 2013, 07:05
OJ
Multphase problems are tricky to model and often transient - especially when Eulerian models are used. Are you running steady or transient?
OJ
Old   June 7, 2013, 11:45
Im running with steady. I gave heat transfer as well. But could not observe any changes ..
3 phase flow, 3 phase flow separator, convergence, multiphase
Modeling unsteady multiphase flow in porous media - convergence problem Vaibhav Kumar Main CFD Forum 1 July 22, 2012 04:32
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem anon_b CFX 11 May 6, 2012 20:16
Phase selection problem in open channel flow shoumo_30 FLUENT 1 December 1, 2011 02:48
Problem with Convergence at high flow rates Syed Siemens 1 April 10, 2007 15:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
