Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
mixing two liquid
Like Tree1Likes
  • 1 Post By pesar125
Old   December 16, 2013, 02:06
Unhappy mixing two liquid
mostafa
pesar125 is on a distinguished road
hi my friends
i try to modelling the static mixer in fluent that mixed two liquids with the different density, the problem is 3D.
how do i do it?
what do i use the model viscous?
k- epsilon or k-omega or reynolds stress or detached eddy simulation??
VOF or mixture or aulerian?
pesar125 is offline   Reply With Quote
Old   December 16, 2013, 13:03
Zaktatir is on a distinguished road
-If your fluids are continuous and are interpenetrating each other and could separate then use the full eulerian approach. If they tends to separate then VOF> Please reply upon this or whether one fluid is injected as dispersed particles into the existing fluid.
-I assume that your flow is turbulent you can start using the k-epsilon model with enhanced wall treatment (as first instance)
-Enable gravity and give the density of your lightest phase as the reference one
-Start first of all doing some tutorials in multiphase and turbulence
Zaktatir is offline   Reply With Quote
Old   December 16, 2013, 15:09
Red face
mostafa
thanks for your helping my friends
you mean i should use the aulerian method?
one of the liquids is water and the other liquids is the condensate product with 735 kg/m^3 density. in this static mixer i try to full mixing within liquids. the water with 3.75 kg/s and the condensate product with 20 kg/s enter the mixer that is the pipe with internal blade for mixing and the mixer size is 1500mm. the problem is 3d and i have problem with mesh this.
please help me to find doing some tutorials in multiphase and turbulence
moriss likes this.
UDF for droplet of immiscible liquid mixing boh_tea FLUENT 0 March 7, 2011 21:43
help( solid and liquid mixing) sanaz Main CFD Forum 1 October 21, 2009 01:41
[GAMBIT] help( solid and liquid mixing) sanaz ANSYS Meshing & Geometry 6 October 15, 2009 10:25
governing equations for liquid mixing with free surface? phsieh2005 Main CFD Forum 3 October 6, 2009 20:37
Need some help for total liquid fraction linus FLUENT 0 December 19, 2006 03:29
