Rep Power: 0 ![]() |
Hi everybody,
I'm doing simulation on sound reduction through closed cell porous media as a sample. The sample is placed in a middle of two tubes namely upstream and downstream. Each tubes has two microphones as to captured the pressure generated by a soundsourse/speaker at the upstream. I assumed that the pressure at the downstream should be lower than the pressure at the upstream due to resistance of the sample. However I got otherwise... I used Ergun equation to calculate viscous resistance and inertial resistance of the porous sample, 1.9407e7 and 4465 each. I run the model at 300Hz, using Static Pressure, I got the pressure in Pa at each point of the microphones.. Using the pressure value I calculated the Sound Pressure Level (SPL)..am I right..? I got SPL at the upstream or in front of the sample is lower than the back of the sample or at the downstream.... ![]() Maybe someone can help me...TQ. |
impedance tube, pressure, sound pressure level, viscous resistance |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
pressure inlet for shock tube!!! | showwa | FLUENT | 0 | December 24, 2008 02:10 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
