July 31, 2015, 07:40 |
VOF Modelling
Thiago
Rep Power: 10 |
Hello!!
I am a new Fluent user. I started working on my Master Thesis right now and it involves Fluent/CFD; I need to model a single elongated bubble (Taylor bubble) flowing within a column of stagnant liquid. I know I should use VOF model for that since I want to track the bubble advance within the liquid pipe. Someone can help me with that? How can I start implementing this problem, like boundary and initial conditions and how to introduce a single bubble in this problem? I read Fluent Tutorial and user s guide but it did not help me very much.... Thanks since then I really appreciate if you can help me with that.... |
August 17, 2015, 07:17 |
VOF Modelling
kelich
Rep Power: 13 |
Hi
in summary you have to do the following steps: 1- create your model 2- generate a good mesh (structured mesh is better) 3- setup your physical model like as unsteady, two phase, turbulence, ... 4- choose VOF model (obviously you have not mass or heat transfer) 5- choose liquid as a primary phase and air or gas as a secondary phase 6- active gravity and define gravity in the correct direction 7- initialize the problem in which the you domain will be filled by primary phase 8-** you have to patch the secondary phase (initial place of bubble) : you have to mark an adapted region (bubble initial place) in adaption form 9- run as you know these steps are the most important. if you want some more detail, I can help you. by the way see these link: http://www.aparat.com/v/QSApg http://www.aparat.com/v/3mMhf |
August 17, 2015, 07:40 |
Thiago
Rep Power: 10 |
Thanks a lot, mrkelich!!!
I really aprecciate it! Actually, I made it and my main worry right now is to plot a transient chart: velocity of the bubble front versus time. Do you have any idea on how doing that without coding??? |
August 17, 2015, 07:46 |
velocity
kelich
Rep Power: 13 |
I have not fluent software in front of mine right now. I'll tell you as soon as possible.
August 17, 2015, 07:51 |
velocity
kelich
Rep Power: 13 |
the simplest but the poorest way is you create a pint almost in center of bubble at some times, read the velocity and then plot it manually. as you know the velocity is almost equal entire of bubble
August 18, 2015, 08:11 |
Thiago
Rep Power: 10 |
mrkelich, how can I read the velocity at any point inside the bubble? There is any function in Fluent which can do that for me?
August 18, 2015, 08:29 |
Thiago
Rep Power: 10 |
actually i need to track the bubble nose velocity, do you know how can i do that?
August 18, 2015, 14:39 |
bubble
kelich
Rep Power: 13 |
1- Go to surface (in main menu bar) and choose the Point
2- You can use the select point with mouse for visual selecting or enter the any point coordinate Draw contour (phases : phase-2 manual range 0.9-1) to capture bubble boundary and select the point by Right Mouse Click) 3- create the pint 4- finally you can read the flow parameters by plot or reports options. as I told this is the simplest and poorest way. |
August 20, 2015, 11:56 |
#9 |
Thiago
Rep Power: 10 |
Many thanks, man!
I have one final question and I wonder if you could help me out with this one: I am trying to set up a Taylor bubble 2D flowing within a column of stagnant liquid. Initially I have water on the top of the tube and gas below it. They are initially separated from each other. What I need to do is the following: It is necessary to disturb the interface in the 2D axisymmetric simulations in order to have a flow. The interface can be disturbed by setting the gravity in the opposite direction for a small time of period. After the interface was disturbed the gravity was set in the normal downward orientation again. Immediately thereafter a bubble was seen to move upward as the liquid was falling downward. How can I do that??? Disturbing the interface? Thank you man |
August 22, 2015, 00:10 |
taylor
#10 |
kelich
Rep Power: 13 |
you have to patch your domain, liquid is on the top of the tube and gas below it at t=0., and also setup gravity in the right direction.
personally I prefer to do in 3d than ax-symmetric. send your email and I'll send you an example of Taylor bubble in 2d. |
August 22, 2015, 05:32 |
#11 |
Thiago
Rep Power: 10 |
Yes, I did what you said. Actually I need to model it first in 2D case... I guess the problem is on which direction should I set the interface in order to dirturb it in the beginning. I know that after the interface is disturbed I set the gravity in the -y direction. But in the beginning is problem....
Anyway, my email is tsaumagomes@poli.ufrj.br I really appreciate your help!!! |
September 5, 2015, 01:32 |
2d bubble column simulation
#12 |
surya
Rep Power: 10 |
hello sir
i would like to know how to model if we have separate inlet for gas and liquid (liquid column is not stagnant)which is flowing in same direction. |
bubble, liquid, mulitphase, vof modeling |
VOF modelling, water drainage from an elevated tank | ashraf88 | FLUENT | 5 | November 29, 2013 08:05 |
VOF modelling, water drainage from an elevated tank | ashraf88 | Fluent Multiphase | 0 | November 28, 2013 06:44 |
VOF modelling, water drainage from an elevated tank | ashraf88 | Fluent Multiphase | 0 | November 28, 2013 06:37 |
Modelling capillary forces using the VOF Model | alere | FLUENT | 1 | October 28, 2013 10:14 |
Modelling flow around a ship's hull using vof | Manoj Kumar | FLUENT | 0 | February 26, 2005 16:22 |
