Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Heat transfer problem with Phase Change Material
Old   August 5, 2016, 09:21
Default Heat transfer problem with Phase Change Material
Obi
obiscolly50 is on a distinguished road
Hi all,
I'm trying to simulate heat transfer to a phase change material. As can be seen from the attachment, there is an annular space for storage of the PCM (with air space at the top to allow for expansion) and hot fluid (glycol) flows though the center. The body is made of aluminium. I've initially practiced with 2 phase flows that involves direct application of heat to the PCM surface, but i'm a bit confused to how to approach this problem? I enabled the VOF model with 2 eularian phases and melting and solidification. However, under the cell zone condition for glycol, there is no drop down menu to specify glycol as material. Could it be that i should analyse this as a 3 eularian phase model (for pcm, air and glycol) even though there is no physical interaction between the glycol and pcm? If not, please i need suggestion on how to approach this. Thanks.
obiscolly50 is offline   Reply With Quote
Conjugate Heat transfer with phase change cfdsolve FLUENT 0 August 4, 2016 08:02
How to simulate the flow and heat transfer of phase change materials? rosol FLUENT 9 April 10, 2016 14:22
Radiation interface hinca CFX 15 January 26, 2014 17:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
