Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
height of the interface
Old   September 18, 2015, 16:23
Default height of the interface
bahare babaee
babaee is on a distinguished road
I have carried out a multiphase simulation of water/air using VOF.
I'm interested in knowing the height of the interface between the water/air. How could I do it?
babaee is offline   Reply With Quote
Old   September 29, 2015, 07:06
Default Interface height
landerfwc is on a distinguished road
Firstly you have to define, what is considered to be an "interface height" - If you will plot two-phase interface by 2 contours, you will obtain an accurate contour with NO height of interface. When you choose more contours when plotting, you can deduct some height of interface however, where this starts and ends? At contour of 1%, 5%, 10% portion of the second phase? You must be the one to determine. It seems to be easily found out from the picture attached.
landerfwc is offline   Reply With Quote
Old   October 25, 2015, 06:31
luccy is on a distinguished road
hi
i must have 2 color in my simulation,red for water and blue for air,but i have more color between red and blue, and i dont determine water depth,how can solve this problem?
tanx
luccy is offline   Reply With Quote
Old   October 26, 2015, 01:34
Default Contours
In countours, set No. of levels to 2.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
