Pre-fill flow domain with 2 phases flow inlet. |
October 14, 2015, 04:50 |
Kaichung Wong
Rep Power: 14 |
http://www.cfd-online.com/Forums/att...1&d=1444812878
http://www.cfd-online.com/Forums/att...1&d=1444812947 Dear All, I'm currently met with some obstacles on the Eulerian Multiphase Model. I had run through the tutorial and with no problem on it for the Eulerian 2 phase model. Please refer to the schematic diagram attached with this thread. The desired end results are also included. My problem now is that I want the flow domain to be pre-fill with blood (Dynamic Viscosity = 3 mPa.s). The 2 phases (Detergent Liquid and Air) will be entering from right hand side of the tube. I wrote a UDF and ran it. The UDF code interpreted with no errors. It is not showing what I want at the end. My UDF code is attached with this thread. Any help and suggestions are very much appreciated. Yours sincerely, Kaichung Last edited by KaichungWong; October 14, 2015 at 05:08. Reason: My schematic diagrams are missing. |
initial conditions, multiphase flow |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
