Water droplet on surface, problems with interface water/air (video / setup included) |
November 24, 2015, 18:09 |
Rep Power: 10 |
I'm new to CFD (I've done several tutorials etc.). Bascially what I'm trying to do is to simulate marangoni convection along a surface in 2D - that's what I hope to achieve eventually anyway. At the moment I'm battling smaller problems on my way to that goal. The domain is 5x15mm (2D) completely walled in, VOF 2 phases (air / water), surface tension incl. wall adhesion (90° contact angle). As you can see in the video and pictures, within 0.35s the water region expands quite a bit. There is no hard line between air and water, which I feel should exist. I have added the complete setup in the pictures, I would appreciate it a lot if someone experienced could glance over it. I feel like there must be some essential error in the setup. Video: https://www.youtube.com/watch?v=FzzqNcvDeVU Setup Fluent: http://imgur.com/a/kUXF9 |
December 7, 2015, 03:40 |
Rep Power: 13 |
Guess you will get a "hard line" only if the mesh is sufficiently fine. If a cell is filled with 0.1 fraction of water how do you expect to see a "hard line".
The same cell is sufficiently small will have a much larger volume fraction of water. Not sure though, that is just my view on this... |
Water Surface Evaporation | sunggun1212 | FLUENT | 3 | January 11, 2020 04:12 |
For a single phase flow, is there any way to check water surface level? | Tanjina | FLUENT | 0 | February 23, 2014 22:56 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
