Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase VOF not converging
Old   March 18, 2016, 06:58
Default Multiphase VOF not converging
Syed Aaquib Hazari
hazari.aaquib is on a distinguished road
I am simulating a steady state stratified two phase 2D channel flow with periodic boundary conditions.
The residuals (all) oscillate for the default values of URFs. However, when I reduce the residuals of k, w & P to 0.1 the oscillations vanish and the solution converges (extremely slowly).
Is it advisable to do so?
P.S: I have changed grid sizes, ran unsteady state simulations. Nothing seems to prevent the oscillations when the URFs are at default values.
hazari.aaquib is offline   Reply With Quote
Old   March 18, 2016, 07:05
Cees Haringa
CeesH is on a distinguished road
what Courant criterion do you use?
CeesH is offline   Reply With Quote
Old   March 18, 2016, 07:56
Syed Aaquib Hazari
Is there a Courant criterion for steady state simulations?
The VOF method meanwhile was implicit and not explicit. So no Courant Number here either.
Am I missing it somewhere?
Old   March 18, 2016, 09:52
Cees Haringa
No, there is no Courant criterion for steady state simulations. Then again, it is questionable how much of VoF remains in a steady state implicit method. I've seen some discussions on this topic on the forum before and don't think they were ever fully conclusive. In the implicit steady state method, the sharp interface tracking (PLIC) method is - as far as I know - not available.
Anyway, what is the goal of your simulation? Because most applications I can imagine you would use VOF for, do not benefit really from a steady solution. What is it you want to study?
Old   March 18, 2016, 10:24
Syed Aaquib Hazari
The topic is: Modelling of Turbulent Stratified Two Phase Flow in a Channel.
Presently, Fluent fails to accurately predict a simple turbulent two phase channel flow. The interface behaves as a rough wall and the turbulent kinetic energy here is not damped.
An in house MATLAB code successfully predicted the flow with an imposed value of omega at the interface using the Wilcox slightly rough boundary condition (Wilcox, 2006).
I have already used a UDF in fluent to incorporate the same Wilcox condition at the interface, it works and the outputs are in agreement with the MATLAB code. However, to be completely sure of the solution I need to get rid of the oscillations and obtain convergence.
I've read through an ANSYS document and it suggests that the VoF can be used in steady state if the solution is independent of the initial conditions.
Old   March 22, 2016, 01:12
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Did you try turbulence damping in Fluent? You may not need UDF for that.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 22, 2016, 03:34
Syed Aaquib Hazari
Yes, I have tried turbulence damping indeed it does work.
However, the damping coefficient is dependent on the grid size and this value needs to be obtained through trial and error.
The UDF meanwhile is grid independent.
Multiphase VOF not converging hazari.aaquib ANSYS 0 March 18, 2016 06:57
VOF multiphase - Validity of Fluent ? manxu FLUENT 2 January 2, 2014 11:17
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 08:41
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 10:37
VOF transfer - multiphase flow karthik Main CFD Forum 4 February 2, 2006 01:25
