Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase Fluidized-Bed Chemical Reactions Imbalance
Old   July 27, 2016, 18:28
Exclamation Multiphase Fluidized-Bed Chemical Reactions Imbalance
Jack_lumber is on a distinguished road
Hi everyone!
I'm trying to model gasification and combustion in a fluidized bed in Fluent.
I've defined the rate of the reactions into the "phase interaction" panel through the use of UDFs.
The kinetics work fine for the primary phase (gas phase composed of co,co2,h2,h2o,o2 and argon) I obtain good results for the species in the primary phase i.e. for h2o gasification the h2o mole shrinks and h2 and co are produced.
However, the model doesn't work for the secondary phase consisting of only pure carbon. When the reactions take place, the carbon content increases instead of decreasing.
Any suggestions? Anybody experienced/resolved the same issue?
cheers
Jack_lumber is offline   Reply With Quote
Old   July 28, 2016, 14:49
So the problem seems to come from the density definition:
when I set the solid phase density as "incompressible ideal gas" the reaction works as expected, however, the density of the solid phase becomes very low (way below the 350 kg/m3 I measured for my feedstock). This is the reason I was assuming a constant density of 350 kg/m2 before.
How could I overcome this? I need to define a solid phase density of 350 kg/m3 but the reactions only work by considering the solid phase as an incompressible ideal gas... I'm a bit confused...
Old   October 23, 2016, 22:41
Jay Yin is on a distinguished road
Could you make it more clear why you think carbon is increasing instead of decreasing? From my experience, if solid phase include only carbon, its mass fraction will keep unity, however its volume fraction will decrease as expected.
Jay Yin is offline   Reply With Quote
Old   December 3, 2016, 12:18
Dri
Adriana
Dri is on a distinguished road
What is the volume fraction of the secondary phase, and what are your boundary conditions?
Dri is offline   Reply With Quote
combustion, fluidized bed, heterogeneous reaction, multiphase
multiphase flow ,mass and volume fraction imbalance sope111 CFX 16 September 3, 2018 00:10
How are chemical reactions stored after parsing? DanielW OpenFOAM Programming & Development 3 June 7, 2018 14:39
Conservation problem Eulerian multiphase fluidized bed shadowfax Fluent Multiphase 0 October 14, 2015 09:32
Multiphase liquid-solid spouted bed: pressure problem ghost82 FLUENT 7 November 10, 2013 12:12
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 21:10
