Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
FLUENT two-phase mixture method for nanofluids
Like Tree1Likes
  • 1 Post By Lancashire
Old   October 12, 2016, 12:47
Default FLUENT two-phase mixture method for nanofluids
Andrew Vella
Lancashire is on a distinguished road
I need to compare results for a simulation with nanofluids in a coiled tube using the single-phase and the two-phase mixture methods in FLUENT. The single-phase method works perfectly well. However, I am confused with the development of the two-phase Mixture model. The pertinent literature states that the fluid properties need to be defined through the use of the effective properties (as in the single-phase simulations). Hence, I am not sure how to define the model in FLUENT.
Therefore, if we define a Mixture model with two-phases, my understanding is that the base fluid properties (water) will be defined with UDF’s for the effective properties. Then how can be define the properties of the nanoparticles i.e. The second phase?
Am I right to assume that for the second phase, the granular option needs to be activated? This will then allow us to define the diameter….
pankajadgjmp likes this.
Lancashire is offline   Reply With Quote
Old   October 18, 2016, 09:55
Andrew Vella
Hello! Is there anyone out there who is able to give a hand with this
Old   October 19, 2016, 11:44
Default hi my friend
hassan
bazaee is on a distinguished road
send your case&data for me.
i can fix it for you.
best regard
bazaee is offline   Reply With Quote
Old   October 19, 2016, 11:45
Default my email address
hassan
Bazaee.Hassan@gmail.com
Old   April 4, 2017, 03:53
Smile
pankaj sharma
pankajadgjmp is on a distinguished road
why udf ?
simply select water as your primary fluid. And yes granular needs to be activated.
i have done this but the simulation has failed till now because if i set the dia as e^-9. And if i set it around e^-6 or above the simulation runs fine.
if you have any answer to the above problem please let me know.
accessaccount32@hotmail.com
thanks
pankajadgjmp is offline   Reply With Quote
Old   April 4, 2017, 03:54
pankaj sharma
did you find any solution??
Old   April 5, 2021, 10:09
Taheri is on a distinguished road
Hi
I have a problem similar to yours. Were you able to solve it?
Taheri is offline   Reply With Quote
multiphaseEulerFoam: method iter() and calculation of phase fractions maybee OpenFOAM Programming & Development 1 July 22, 2020 08:20
2 Phase Flow, Gas Jet into Water Simulation Method im_lenny OpenFOAM 3 May 4, 2017 03:20
three phase simulation in fluent monababaei Fluent Multiphase 6 October 3, 2015 02:59
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
Ghost Fluid Method in Fluent ndabir FLUENT 0 February 3, 2015 08:44
