February 14, 2017, 18:22 |
fluent udf compiling Error Object: #f
tony
The UDF library you are trying to load Copied
Copied C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\1.c to libudf\src udf_names.c and user_nt.udf files in 3ddp are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\v160\fluent"\fluent16.0.0\sr c\udf\makefile_nt.udf "libudf\win64\3ddp\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp")# Generating ud_io1.h Done. Opening library "C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\C: \Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\libud f"...RPC RCX_SC_SET_ERR_MSG failed: RPC: Can't encode arguments Error: The UDF library you are trying to load (C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\li budf) is not compiled for 3ddp on the current platform (win64). The system cannot find the file specified. C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\C:\ Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\libudf \win64\3ddp\libudf.dll Error: The UDF library you are trying to load (C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\li budf) is not compiled for 3ddp on the current platform (win64). The system cannot find the file specified. C:\Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\C:\ Users\Tony\Desktop\1\1_files\dp0\FFF\Fluent\libudf \win64\3ddp\libudf.dll Error Object: #f im operating on windows 64 10, ansys 16 i have a uni project about a catamaran hull moving in calm water im a beginner wish any could help thanks |
February 15, 2017, 01:18 |
Alexander
Rep Power: 9 |
It looks like you use compiler win32. You have to compile your UDF in win64.
February 15, 2017, 08:40 |
tony
How To do that ? Thnx
February 16, 2017, 03:08 |
Alexander
Rep Power: 9 |
Install 64bit compiler (visual studio express for example), make sure you use 64bit version (in compiler setting). Sometimes you have to set system variables additionaly if instalation was not correct
compiling error(s), error object: #f, fluent, udf |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Error while compiling udf in fluent 13.0.0 | siddharth12 | FLUENT | 0 | December 3, 2013 16:46 |
compiling my UDF | Seyed Farid Hosseinizadeh | FLUENT | 22 | February 14, 2006 10:19 |
