Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to Patch by Zone to Initialize Complex VOF Geometry
Old   January 3, 2018, 19:31
Default How to Patch by Zone to Initialize Complex VOF Geometry
R. Kim Eadies's Avatar
R. Kim Eadies is on a distinguished road
I am running a VOF model of a wastewater pump station where pumps and their respective piping need priming by initializing with water. I am familiar with Region Adaption for simple geometries, and I am sure, as with most things, that a UDF could also be employed, but it seems most practical to patch by zone, having separated the regions of interest into a separate zone when creating the geometry. The new zone appears under Solution Initialization>Patch>Zones to Patch, and upon patching it I receive expected text in the console window, however there is no patched phase when I view a contour plot.
I have already checked for common blunders, such as remembering to set water for secondary phase, and also created a simplified case to test patching by zone, but I get the same result, or lack thereof. I realize I could get away with a number of "cheater" approaches with Region Adaption, as any excess region patched would just drain down to the floor, and any missed region would result in an air bubble that would get pumped out of the system, both with negligible effect on the result I'm after, but I'd like to know how to patch by zone on principle of the matter, and to add something new to my CFD toolbox. Any insight is appreciated.
Attached is a screencap of the geometry with the zone to patch highlighted in orange.
Thanks,
Alan
R. Kim Eadies is offline   Reply With Quote
Old   January 4, 2018, 09:50
annan
annan is on a distinguished road
Do you specify the right water volume fraction (1 in your case) when you patch the zone ? Simple question maybe but it happens sometimes to forget about it ...
Good luck
annan is offline   Reply With Quote
Old   January 4, 2018, 11:44
Annan,
Thanks for your reply. Yes, I have set the volume fraction to 1. As far as I can tell, I have done everything the same as with the Adapt>Region approach, which leads me to believe there is something I don't understand about how cell zones work. Reading the User's Guide again to see if there is something I missed.
Thanks again,
Alan
"The more you do what you're already doing, the more you'll get what you've already got."
complex geometry, complex initialization, initialization, patch by zone, separate region
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
