May 10, 2017, 05:24 |
Heat flux coefficient at VOF interphase
Andreas Ammann
Hi
I'm currently running a simulation of an oil bubble rising in water. The bubble has a lower temperature than the continuous water-phase. My target is to evaluate the heat fluxcoefficient at the interphase between water and the oil bubble. Setup: 3D-Mesh with quads VOF (not coupled level set) Energy equation on ic: 0 velocity flow field, spherical patched bubble with phase 2 for oil bc: walls and gravity In my opinion the result of the rising bubble looks plausibel, the temperature distribution over time too. But if I want to evaluate the heat flux coefficient by doing the following steps I get 0 w/2-k: - Create an isosurface with a VOF value of 0.5 - Reports/Surface Integrals - Choosing Area Weighted Average, and surface heat transfer coefficient under wall fluxes - choosing the isosurface and evaluate If I plot the heat flux as a contour plot on the isosurface I also only get 0 w/m^2. But my temperature field tells me an other story. Is it actually possible to evaluate the heat flux at the interface? And if so, how? Best Andy |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Heat flux and Heat transfer coefficient | sakil2k3 | FLUENT | 4 | July 5, 2015 15:07 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
