Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fail to define a single phase fluid after turning on VOF
Old   June 28, 2017, 01:35
Default Fail to define a single phase fluid after turning on VOF
vivienne
Vivienne_Y is on a distinguished road
Dear all,
I am trying to model a double pipe heat exchanger with the heat transfer fluid flowing inside the inner pipe to melt the PCM in the annulus. Air also exist in the annulus part, so I used VOF model to model this part. After I activating VOF model, when I define the inner fluid, it regarded inner heat transfer fluid as mixture of two phases defined in VOF model. I want to define inner fluid as another material. How can I solve this problem? Do I have to write UDF to solve it?
Vivienne_Y is offline   Reply With Quote
fluent, single-phase, vof
Two phase flow VOF ( fluid didn't fill the whole pipe) M.Yosry Fluent Multiphase 1 April 22, 2016 08:39
coupling vof with single phase flow and gravity term alame005 Main CFD Forum 7 August 6, 2013 11:02
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
