Evaporation model, why the fluid temperature is NOT constant? |
September 12, 2017, 22:05 |
Vincenzo
Rep Power: 8 |
I'm simulating evaporation through a pipe. Water is flowing inside it and it gets heated with certain heat flux (1077328 W/m^2). It's subcooled water, it enters at 20°C and 2000 PSI, over a 16 m leght it must evaporate around 80% of the fluid. The thing is, I do get the fraction correct, around 80% but when I plot the temperature of the liquid to check the leght when starts the evaporation I found that the temperature of the liquid along the leght keeps rising! it gets more than 1000 K which is impossible since all the energy is used to change the phase and not to increase the temperature.
So, what's happening? Did I miss something to configurate? Is a flaw in the model? My boundaries conditions are: Pressure based 2D symmetrical Turbulent k-epsilon Water liquid (propierties are piecewise linear to get more close to real values, beacuase water at 320°C has a Cp over 6400 J/kg K) Water vapor (properties remains constant) steel (properties constant) Inlet: velocity Liquid V=0,484 m/s T=293K Vapor V=0, Fraction=0 Outlet: Pressure Gauge pressure= 0 Backflow Temperature=335,472 °C (Saturation temperature) Vapor Blackflow =0 Wall Heated: Wall Thermal q=1077328 W/m^2 Axis: Axis Operating conditions: 2000 psi Phase 1: Liquid Phase 2: Vapor Interaction: evaporation condensation Frequency 0.1 Saturation temp: 335,472 °C Everything else is default. So what i'm doing wrong? I'm missing something? can someone help? Thanks for your time! |
September 14, 2017, 03:42 |
Rep Power: 8 |
I would say that this effect would depend on the fluid properties and the vaporization model you're using. I suggest you to check in the theory manual the equations you're using.
Sent from my SM-G935F using CFD Online Forum mobile app |
evaporation, fluent, temperature |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
