September 18, 2017, 04:31 |
Critical Heat Flux in a Pipe
ChenChong
Rep Power: 8 |
Hello,I have some problems about" Fluid Dynamics Verification Manual" VMFL067 Boiling in a Pipe-Critical Heat Flux,the problem described as follow Figures .I have just simulated the case base on the introduction,and all the conditions and models are consistent,the inlet temperature is 555k. but I can not get the same result.I used the Boiling model-critical heat flux,turbenlent model:RNG k-e.The calculated wall temperature distribution show as follow figure.Have someone ever done this case? Beg for your help! Thank you!
December 20, 2017, 00:07 |
Yun MO
Rep Power: 9 |
Get the case file from Ansys's home page and check the settings in the model. There are a lot of settings you have to carefully select.
December 20, 2017, 01:11 |
#3 | |
ChenChong
Rep Power: 8 |
December 20, 2017, 18:55 |
Yun MO
Rep Power: 9 |
You can obtain it directly from Ansys support if you are a user of Ansys Fluent. Ask your local Fluent service to get a support services ID.
December 20, 2017, 21:02 |
ChenChong
Rep Power: 8 |
December 21, 2017, 03:50 |
Yun MO
Rep Power: 9 |
Check your mail, please.
December 22, 2017, 02:38 |
#7 | |
Hao su
Rep Power: 9 |
my e-mile:401236355@qq.com thanks |
December 22, 2017, 02:45 |
Hao su
Rep Power: 9 |
February 9, 2018, 14:00 |
Osm Bln
Hello for every one, I also trying to model a channel analysis in which the water enters subcooled and then a want to simulate the critical heat flux conditions. Before this simulation I solved the two phase boiling problem which has about 0.6 outlet void fraction. For water and vapor phases I entered the material properties by hand.
I want to ask, do I need to follow same methodology for material property manupulation in CHF simulation. If yes, how? Also, the e-mailed files may help me, would you please send they to me? e-mail: osman.bilen@hotmail.com Last edited by osmbln; February 11, 2018 at 02:58. |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
Heat Flux Profile at Fluid-Porous Interface | Hitch8 | CFX | 4 | December 15, 2012 09:57 |
Heat Flux , Convective + Radiant Heat flux | Mandeep | CFX | 3 | October 25, 2012 16:57 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
