Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Site Species Surface Coverage on Particles.
Old   July 23, 2023, 02:26
Default Site Species Surface Coverage on Particles.
Bluewhale is on a distinguished road
How does Fluent calculate species surface concentration using the defined species mass fractions for a given particle diameter?
I cannot define a site density on a particle like we do for walls to determine surface coverage. I have a predefined initial surface site density which will dictate the mass fractions on the particle surface. I'm not sure how Fluent will use the density of the site species, surface area and mass fraction to get the initial particle site density.
Thanks in advance.
Bluewhale is offline   Reply With Quote
dpm fluent
[snappyHexMesh] Layer coverage at 98% with collapses at corners oryx OpenFOAM Meshing & Mesh Conversion 1 December 4, 2023 19:04
export a position contour on a surface for tracked particles tsh850227 CFX 0 April 14, 2016 03:30
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Selecting mixture of species as "mass-flow-inlet" on a surface using UDF Bharadwaj B S Fluent UDF and Scheme Programming 0 April 7, 2015 08:09
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
