March 21, 2018, 07:30 |
Flow water in channel with zero speed
Illia Leptiukhov
Hi users. Can you help me, what's kind of parameters i must turn on for modelling water flow in vertical channel with zero speed? The water must flow down on the wall, with influence of gravity only. I turned on the gravity, VoF model, k-epsilon model, added 2 phases (air primary, water secondary), but on the end of modelling, water doesn't flow. I modelled flow with velocity 0.5 m/s, there all is ok. Who worked with gidraulic flow, please hint me. Thanks. I attached the pictures of channel with water velocity 0.5m/s. If you need something else - tell me.
channel flow, flow 3d, multiphase flow, vof model |
Advice on open channel flow for an water intake chamber | jcox675 | CFX | 11 | September 4, 2014 07:28 |
compressible low speed channel flow | -Ali | OpenFOAM Running, Solving & CFD | 11 | May 9, 2013 07:40 |
Increasing level of water two-Phase Channel Flow | nore5 | OpenFOAM Running, Solving & CFD | 16 | March 25, 2013 03:24 |
OpenFOAM open channel flow downsteam boundary condition | Brickman | OpenFOAM Running, Solving & CFD | 2 | November 5, 2012 20:14 |
water channel flow with non symmetrical solution | bruce | OpenFOAM Running, Solving & CFD | 1 | October 21, 2011 12:00 |
