March 22, 2018, 05:31 |
Momentum source to model mixer
Rep Power: 8 |
Hello All,
I am modeling mixing of oil and water in a tank with a mixer mounted on the tank wall. I want to see using CFD if the mixer is doing its job to keep the oil in suspension form and not letting it to form a separate layer at the top. I am solving transient simulation using VOF multiphase model. To model the free surface of oil/water mixture, I used symmetry BC. To avaoid the complications in meshing, I am modeling mixer as cylindrical fluid zone with MRF to model its rotation and specifying momentum source to model the thrust produced. I want to know if this is the correct approach to model the mixer. I want to avoid sliding mesh and complicated mixer blade geometry. Please let me know your input. Thanks. |
C_UDSI_G use in momentum source term in eulerian model | Nishan | Fluent UDF and Scheme Programming | 1 | May 30, 2017 06:13 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
