Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Evaporation-Condensation in a porous zone (Heat transfer problem)
Old   July 20, 2018, 04:10
Post Evaporation-Condensation in a porous zone (Heat transfer problem)
Maximilian
maximilian-1 is on a distinguished road
Hi there,
I'm in the midst of my bachelor's thesis and I am supposed to model a moistened insulation.
The insulation material is supposed to be foam glas gravel, which I modeled as a porous zone inside a cube with 1x1x1m as dimensions. The cube is modeled as a cube with walls on all sides. There is no in- and outflux.
My goal is to simulate the heat transfer from the heated bottom (fixed temperature) to the cooled top (fixed temperature) of the cube, in order to get the heat flux through the insulation. The heat flux is monitored through the heat flux trough heated bottom wall of the cube. With this information it should be possible to calculate the effective heat transfer coefficient.
The effect of evaporation-condensation of water inside the insulation on the heat transfer is tried to be found. I am using the Mixture-Model with three phases: air, water-liquid and water-vapour. I activated the Evaporation-Condensation Model. I patched the volume with air and water-vapour with a volume fraction of saturated air at the patched temperature of 308.15K.
I do get phase changes inside the cube with the evaporation-condensation model. The standard state enthalpy of water-liquid and water-vapour are changed, so that they fit the actual latent heat of vaporization (4.40e+07 J/kmol). In my tries I also tried different standard state enthapy values for both water-liquid and water-vapour, but the heat transfer didn't change.
My main problems are:
- As soon as I try to simulate in a steady simulation I get temperature values above 5000K and below 1K, and Fluent returns a floating point exception.
- If I simulate the model in a transient simulation and let it run until the transferred heat through the bottom of the cube is constant, the transferred heat is way to high. (According to measurements it should be around 7 watts, but I'm getting something like 30-40 watts).
Has anyone ever tried to model a closed volume with the evaporation model and got it to work? Has anyone got any idea why the heat flux is so high?
Any help would be highly appreciated, as I am on this simulation for 3 months already and starting to get pretty frustrated.
Thanks! Maximilian
maximilian-1 is offline   Reply With Quote
Old   August 22, 2018, 09:42
Default ansys fluent multiphase analysis
kiarash
kiarashniroumand is on a distinguished road
hi everyone i am working on a multiphase fluid simulation in fluent . that is pipe that have a saturated vapor with a cooled wall . after simulation with a acceptable residuals and the temperature contours was good but about volume of fraction of each phase there is no good results and all fluid domain have a constant volume fraction . indeed i wanna calculate amount of condensed liquid . is there anyone can help me ? its so necessary for me ...
and also i m sorry of my bad english :|
here is my email : kiarashniroumand@gmail.com
kiarashniroumand is offline   Reply With Quote
condensation, evaporation, heat transfer, porous zone, student
buoyantBoussinesqSimpleFoam with porous zone (source term) problem cissystef OpenFOAM Running, Solving & CFD 0 May 26, 2015 08:05
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 17, 2014 23:45
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
