Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Periodic Multiphase with Different BC for Phases
Old   March 26, 2019, 09:50
Default Periodic Multiphase with Different BC for Phases
Luiz Oliveira
Luiz is on a distinguished road
Does anyone know if it is possible to set an periodic boundary condition for one phase and for the other set an pressure outlet for example?
I am trying to extract the time-averaged flow of water and at the same time extract an residence-time distributions curve from a certain region of the domain. The problem is that by solving exclusively with a periodic bc I would be re-injecting my tracer that should be advected out.
Luiz is offline   Reply With Quote
Old   March 28, 2019, 17:40
Luiz Oliveira
I managed to keep the periodic condition without allowing any tracer to come back by simply setting an automatic command each iteration. I would set the initial portion of my channel as a marked region and maintain its concentration as zero.
adapt/mark-inout-hexahedron [Inside] [Mouse Clicks] [x0] [x1] [y0] [y1] [z0] [z1] #marks zones which you can patch
solve/patch [domain] [cells] [region] [variable] [value] #patch zones with tracer concentration
solve/execute-commands/add-edit [name] [frequency] ["iteration"/"time-step"] ["command"] #adds an automated command to clear the inlet or outlet
multiphase flow tracer, periodic bc, rtd
fluent translationally periodic boundary can not be used for multiphase modeling zhihuawan FLUENT 0 January 18, 2018 01:08
Multiphase flow with Periodic Boundary Condition luludonotcry Fluent Multiphase 1 March 16, 2016 05:51
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 08:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 17:46
periodic boundary conditions in multiphase model swarnajay FLUENT 1 July 24, 2009 11:04
