November 12, 2019, 07:28 |
Coupling SST to FLUENT and data sharing
Bharath Thumula
"I have a case in which i solved a thermal case in ansys steady state thermal. Now i have the temperature plot on a solid surface. I want to use this temperature as a wall temperature to adjacent fluid in FLUENT. Can we do coupling from SST to FLUENT. I had seen coupling from FLUENT to SST but not vice-versa. Please provide any materials to do it ?
November 12, 2019, 18:13 |
Joshua
Rep Power: 11 |
https://www.scribd.com/document/3536...-Tutorials-181
Page 41 You can use the system coupling toolbox to pass data from steady state thermal solutions to Fluent. Read through the user guide included with your install of Ansys. |
skinnyfluid, stumpy |
Coupling SST to FLUENT and data sharing. | Bharaththumula92 | Fluent Multiphase | 0 | November 4, 2019 03:17 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
