Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
2D Axisymmetric Swirl VOF Simulation - Phase not changing
Old   April 19, 2020, 19:13
Default 2D Axisymmetric Swirl VOF Simulation - Phase not changing
guilhermemd11 is on a distinguished road
I am a newcomer to Ansys Volume of Fluid simulations, so I will appreciate any help!
I am currently trying to simulate, using transient VOF, a 2D Axisymmetric model of a Pressure Swirl Injector. In this type of injector, the fluid enters through a number of tangential inlet ports (an image of the CAD of the injector is attached for better visualization). A PNG of the 2D Axisymmetric model is also attached, with inlet, outlet, walls and axis pointed out.
I followed the Ansys Tutorial Guide (version 18.0) for both an axisymmetric flow and for VOF Modelling. I also tried to mimic the procedure from several scientific papers I read.
What I am trying to obtain is something similar to this simulation: https://www.youtube.com/watch?v=AsxaOl2BAgI
The problem I am facing is that, when I calculate the posed problem, the volume fraction remains unchanged. To check if the problem was in the set up, I changed the solver from Axysimmetric Swirl to only Axysimmetric and changed the inlet boundary condition to axial velocity only, and it seems to have worked (even though the new simulation had nothing to do with the original problem).
I believe the problem may be with the velocity inlet boundary condition I used (also attached as a PNG image). Or not. I would like some insight, especially if some of you have already worked with a similar problem.
Thanks in advance
guilhermemd11 is offline   Reply With Quote
Old   April 21, 2020, 04:14
Default Phase Change
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
In CFD, user has to specify a model for the phase change. It will not change on its own. User needs to know the reason for phase change, such as, evaporation or cavitation or melting, etc. Accordingly, you need to specify a model for the same.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
axisymmetry, injector, swirl, vof
Using Fluent VOF and Lee model to simulate mass transfer of two phase Albert Lee FLUENT 1 May 2, 2019 08:01
Axisymmetric swirl etgau8 STAR-CCM+ 3 January 9, 2017 06:03
swirl inlet velocity for a 2-d axisymmetric flow zahrarashidi OpenFOAM Running, Solving & CFD 2 January 12, 2015 07:01
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
phase changing simulation David Liu Main CFD Forum 3 October 25, 2004 01:43
