Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
particle sampling at outlet
Old   June 9, 2020, 06:38
Default particle sampling at outlet
shohag
shohag is on a distinguished road
i am running simulation of hydrocyclone. i open files for sampling at two outlets. during opening files i click on 'append file' option. but it is showing error unable to append files. 2nd time, i click again the start button including 'append file' option on. then error show and the files contains the header of various parameters which i need. but the files are not updating any parameters. can any one help me to solve this problem.
shohag is offline   Reply With Quote
Old   June 15, 2020, 10:16
Default Unsteady Tracking
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Click on Start and then run the simulation. Once the simulation is completed, then click on Stop. Now, you will see data written into the file.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 13:30
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
Boundary conditions for vortex particle passing through a square domain mtgoncalves OpenFOAM Running, Solving & CFD 0 August 18, 2017 08:47
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 16:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
