Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Could not achieve the Constant Velocity?
Old   March 11, 2021, 10:22
Default Could not achieve the Constant Velocity?
Raj
Rajkool is on a distinguished road
Hello all,
I am trying to simulate a simple two-conduit model. It is a straight double pipe with a length of 5 cm. I want to do thermal analysis at a constant velocity and check heat transfer for different velocities. But when I specify velocity inlet and outflow outlet or pressure outlet. There is an increase in the velocity at the outlet. I would like to take the suggestion to solve the issue and achieve the same velocity at the outlet as an inlet.
Thank you in advance
Raj
Rajkool is offline   Reply With Quote
Old   March 14, 2021, 16:41
Yasser Selima
Yasser is on a distinguished road
Does the density change with temperature?
Compare the mass flow rate at the inlet to that at the outlet. Only worry about mass imbalance.
Yasser is offline   Reply With Quote
Old   March 16, 2021, 05:27
Raj
Yeah, density has a very slight change and can be ignored. But, in my model phase and velocity being constant is a priority as it is solidified melt.
constant boundary, constant fluid properties
non constant object moving velocity set in pointDisplacement cyhpku OpenFOAM Running, Solving & CFD 0 February 2, 2021 02:05
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 01:55
