March 11, 2021, 10:22 |
Could not achieve the Constant Velocity?
Raj
Rep Power: 6 |
Hello all,
I am trying to simulate a simple two-conduit model. It is a straight double pipe with a length of 5 cm. I want to do thermal analysis at a constant velocity and check heat transfer for different velocities. But when I specify velocity inlet and outflow outlet or pressure outlet. There is an increase in the velocity at the outlet. I would like to take the suggestion to solve the issue and achieve the same velocity at the outlet as an inlet. Thank you in advance Raj |
March 14, 2021, 16:41 |
Yasser Selima
Rep Power: 19 |
Does the density change with temperature?
Compare the mass flow rate at the inlet to that at the outlet. Only worry about mass imbalance. |
March 16, 2021, 05:27 |
Raj
Rep Power: 6 |
Yeah, density has a very slight change and can be ignored. But, in my model phase and velocity being constant is a priority as it is solidified melt.
constant boundary, constant fluid properties |
non constant object moving velocity set in pointDisplacement | cyhpku | OpenFOAM Running, Solving & CFD | 0 | February 2, 2021 02:05 |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 11:25 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
How to achieve constant static pressure in inlet? | Zou Jianfeng | FLUENT | 0 | October 21, 2008 01:55 |
