Three Phase Eulerian Multiphase (GAS/LIQUID/LIQUID) |
March 28, 2022, 02:56 |
Neel
Rep Power: 7 |
While modeling three phases in eulerian multiphase, phase "OIL" is asking for diameter. What does that mean?
My case has only one inlet, only air as a dispersed phase having some diameter is entering the fluid domain. Oil is just their in the domain, it is not entering through inlet neither it is exiting the domain. |
June 5, 2022, 21:30 |
xiuchengyu
if you do not use PBM,the oil diameter is the average value(maybe not the real value),and the diamter you used will Influence the result.
diameter, dispersed fluid, eulerian eulerian, fluent, multiphase |
Two phase using Eulerian to Eulerian | moneimharb | FLUENT | 0 | May 4, 2019 06:22 |
Eulerian Wall Film model with Eulerian disperse phase | michujo | Fluent Multiphase | 27 | January 6, 2017 06:15 |
How to access only one phase in multiphase model by UDF | wersoe | Fluent UDF and Scheme Programming | 1 | January 4, 2017 07:11 |
Difference in flow distribution of single phase and multiphase analysis | shivasluzz | CFX | 0 | April 22, 2015 22:54 |
Which phase do pathlines stand for in multiphase flow? | bigfans | FLUENT | 1 | August 14, 2011 14:23 |
