Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Convergence Problems with Wall adhesion
Old   February 16, 2023, 04:34
Default Convergence Problems with Wall adhesion
ehecboy is on a distinguished road
I am simulating the transient heat transfer due to condensation effects by applying the lee model.
I am considering two phases with the eulerian approach: steam and liquid water
When the "wall adhesion" model is activated the mass of the liquid increases exponentially after a certain time--> leading to absolut wrong mass in the system.
When it is deactivated everything looks fine, no unrealistic results. But less condensate adhere to the surfaces.
Has anyone experinced something similar? I am using the CSS surface tension model. Decreasing the time step size (0.01 ->0.005 s) helped just for a few hundret time steps.
This problem occured only with a finer BL resolution. So refining it further would not help I guess. The problem with a rougher resolution is the underprediction of the adhesion forces
ehecboy is offline   Reply With Quote
condensation, continuity error, wall adhesion
Ansys CFD-Post Application Error rushiCFD FLUENT 0 March 21, 2021 07:51
Convergence problems unsteady conjugate heat flow problem when refining mesh Sven_netherlands COMSOL 0 December 2, 2020 04:32
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 11:30
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Problem with wall adhesion MachZero Main CFD Forum 2 July 2, 2013 09:50
