Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian multiphase model momentum divergence
Old   June 20, 2023, 03:55
Question Eulerian multiphase model momentum divergence
Muhammad Faizan
fzmd55 is on a distinguished road
Dear friends
I am trying to simulate PEM water electrolysis with Eulerian multiphase model, where anode side is fed with liquid water and oxygen is the product at anode and hydrogen at cathode. Based on this, I defined inlet at anode as liquid water which is defined as the primary phase and oxygen as the secondary phase. Since there is no oxygen inlet, my inlet boundary condition is primary phase (water) inlet velocity and the secondary phase (oxygen) volume fraction is defined as 0 and velocity is also 0. Based on the faradaic law, I defined the mass source term for both primary phase (water) and the secondary phase (oxygen) as -j/2F and j/4F respectively. When I run the fluent, the volume fraction of secondary phase instantly reaches 1 and primary phase as 0 causing momentum divergence. I have attached the screenshot of model I am using. Please help me fix it.
viscous: laminar:
model: Eulerian (2 phases) Implicit formulation
Drag: schiller-naumann
Lift: saffman-mei
Wall Lubrication: antal-et-al
Heat, Mass: none
surface tension: 0.072
Interfacial Area: ia-particle
Thanks
Faizan
fzmd55 is offline   Reply With Quote
bubble flow, electrolysis, eulerian, multiphase
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 4 September 25, 2023 07:10
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Restitution factor in Eulerian multiphase model m.jahedi FLUENT 0 February 7, 2012 09:43
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 03:42
Lift coefficients for Eulerian Multiphase Model Anastasios Georgoulas FLUENT 0 July 14, 2008 06:13
