Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
A rigid body moved by water within a dynamic mesh.
Old   June 29, 2023, 02:00
Default A rigid body being moved by water within a dynamic mesh.
Iraq
ymya is on a distinguished road
Dear all, I have a cylinder involving a piston being moved by water, as depicted in Figure 1. The water exerts a force on the piston, pushing the water located behind the piston towards the outlet. The mesh employed has an element size of 0.15 mm. I have compiled a User-Defined Function (UDF) in ANSYS Fluent for the properties of water density, water sound speed, and the motion of the piston as a “rigid body” as in the corresponding TXT File. Most simulation settings are in figures 2 through 9. The time step is 0.001 sec.
In my attempts to solve this problem, I have explored three different solution methods: SIMPLE, PISO, and Coupled. Unfortunately, all three methods have yielded the same result – convergence has not been achieved.
I kindly request assistance from anyone who can identify the errors in my work. Furthermore, I would appreciate guidance on how to correctly implement this simulation.
Thank you in advance for your support.
File Type: txt TXT File.txt (1,013 Bytes, 4 views)
ymya is offline   Reply With Quote
How to set boundary layer of a moving body in GAMBIT to a mesh zone for dynamic mesh tomyangbath FLUENT 18 October 12, 2016 06:57
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 05:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[ICEM] Rigid sphere falling through air. Dynamic mesh alexmeier ANSYS Meshing & Geometry 5 June 30, 2010 00:23
