Gas-liquid cylindrical cyclone separator simulation |
June 9, 2019, 12:26 |
Edi Rossi
Hi everyone,
I am new on the forum and I am a beginner with ansys. For my master degree thesis I have to simulate the separation of mixed air and water within a GLCC separator. In the following image there are the operational conditions and the dimensions of my separator. I have drawn my cyclone model on spaceclaim and imported it onto ANSYS, I am looking for guidance for what parameters I should set along with boundary conditions. I have already tried to perform some simulations (steady state) but I can't manage to have convergence. These are the steps I followed: 1-I kept the mesh the simplest as possible -with 10 inflation layers- in order to have a quicker solution ; 2-I have chosen a mixture multiphase model (double precision checked), with phase1 being water ( Volume fraction 0.7) and phase2 being air -but I am not sure I am doing this correctly; 3-I have chosen a Viscous k-epsilon model, RNG with swirl dominated flow; 4-Cell zone conditions- Operating conditions- I checked on specified operating density; 4-The inlet is a velocity inlet . The water is entering at 11m/s and the air is entering at 4m/s ( I got these data from the table of operational conditions, given the volumetric flow rates of gas and liquid). The outlets are both pressure outlets; 5-For solution methods I used a coupled scheme, for pressure PRESTO, for momentum and turbulence equations third order MUSCL; 6- I performed an hybrid initialization in 15 iterations and then I ran the calculation ( steady state, gravity) but in a 1000 iterations the calculation stopped and I didn't have convergence. Furthermore during the iterations it kept popping up this warning message: turbulent viscosity limited to viscosity ratio of 1.000000e+05. In the following image there are my residuals. I also tried with the Eulerian multiphase model, keeping all the others settings: in this case I don't have the warning message but the residuals still don't converge. I don't have experience with ansys, I am just a beginner so I could really use some help. Last edited by Cheza16; June 10, 2019 at 11:45. |
September 18, 2023, 10:26 |
#2 | |
Laura Osorio
gas liquid cyclone |
TomiyamaCorrelated drag model for reactingTwoPhaseEulerFoam | achref_rabhi | OpenFOAM | 2 | March 4, 2019 04:08 |
interFoam with different gas and liquid inlets | phani45 | OpenFOAM Running, Solving & CFD | 0 | May 1, 2017 12:51 |
Ideas about Gas - Solid Cyclone Separator Simulations | ardismo | FLUENT | 4 | April 6, 2016 08:04 |
Ideas about Gas - Solid Cyclone Separator Simulations | ardismo | Main CFD Forum | 0 | January 11, 2016 10:46 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
