February 1, 2024, 01:54 |
Solution diverges when mesh is refined
marcus aurelius
Rep Power: 2 |
I am trying to do a saturated pool boiling simulation on a finned surface using ANSYF Fluent VOF Lee evaporation-condensation model.
I got some initial results without problem with coarse mesh. But, when I refined the mesh to 2 times, the solution diverges at initial time steps itself. I tried reducing the time step (up to 10^-9) and tried first order as well as second order schemes. Also tried switching off turbulence model. I can't understand, how its perfectly working for coarse mesh and blows up for finer mesh with same setup? The pictures for coarse and fine mesh are attached. The snapshot of how resudual are shooting up is attached. Last edited by marcusaurelius; February 1, 2024 at 05:30. |
February 1, 2024, 09:26 |
Joern Beilke
Rep Power: 20 |
10^-9 seems far too small. It often helps to increase the time step size at the beginning of a simulation instead of decreasing it.
ansys fluent, evaporation condensation, lee model, multiphase, volume of fluid |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
Converging the solution | aja1345 | FLUENT | 13 | June 14, 2022 23:46 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
