UDF to change heat transfer coefficient with wall temperature
Like Tree4Likes
  • 4 Post By hatef
Old   May 10, 2012, 05:21
Default UDF to change heat transfer coefficient with wall temperature
Emma
emmkell is on a distinguished road
Hi
I need to change the heat transfer coefficient on a wall with changing temperature on the wall. I have written a simple UDF to change the heat transfer coefficient, which is interpreting into Fluent with no problems, but when I run a monitor on the wall for Total surface heat transfer coefficient it is giving me strange answers with negative values. I know that very low values of ln() will give a negative answer but anything over ln(0.4) in this equation will give a postivie answer. At a temperature of 297, this equation should give a h value of 3.06, but instead it keeps returning a value of 0.0002.
Is my UDF too basic? or is the problem with my monitor?
#include "udf.h"
DEFINE_PROFILE(HTC, thread, index)
face_t f;
real Temp = 293.15;
F_PROFILE(f, thread, index) = 1.2854*log(Temp - 293) + 1.2822;
Or should i be using the return HTC function as is used in DEFINE_PROPERTY which change with temperature also?
emmkell is offline   Reply With Quote
Old   May 10, 2012, 09:05
Daniel Tanner
Daniel Tanner is on a distinguished road
You cannot use Define_Profile this way. There needs to be a loop that loops over each element on the boundary/face of interest.
I ripped the udf below out of the UDF manual. You need to have something of this form (take out the velocity stuff and enter your temperature stuff).
Currently I think your UDF will only apply this correction to the first element of the face!
Let me know how you get on.
vprofile.c
UDF for specifying steady-state velocity profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = 20. - y*y/(.0745*.0745)*20.;
end_f_loop(f, thread)
Daniel Tanner is offline   Reply With Quote
Old   May 10, 2012, 09:27
Emma
Thanks Dan!
I had tried some variations of this but didnt get anything to give the right ht coefficient. I will give it another try just changing the details to what I need.
I read in a couple of differnet threads on this forum that fluent doesnt give accurate readings of heat transfer coefficient from its surface monitor readout and I'd need another UDF to findout what fluent is settin gthe heat transfer coefficient to.
Old   June 9, 2012, 00:23
Ali
alighasemian is on a distinguished road
Hi Emmkell, did you solve your problem? I mean did write a UDF which change the heat transfer coefficient on a wall in terms of the wall temperature?
if you solved your problem could you help me? I have a similar problem!
this is my email: ghasemian.a@gmail.com
alighasemian is offline   Reply With Quote
Old   August 8, 2012, 11:23
Emma
I got this working, I forgot to post it up here, using your recommendation Daniel, thank you!
I had to change y = x[1] to y = x[0] for some reason, i didnt understand what it meant at the time but i understand now that it is picking the values in the x array in either cell 0,1 or 2, so the fact that it worked for me must be something to do with how i set up my geometry?
Changing the wall thickness also helped.
#include "udf.h"
/* UDF Define Temperature dependant heat transfer coefficient) */
DEFINE_PROFILE(htc, thread, position)
face_t f;
real y = F_T(f,thread);
y = x[0];
F_PROFILE(f, thread, position) = 0.7942 + 1.3915*log(y);
Wohoo! Now on to the next UDF problem!
Old   June 19, 2013, 12:40
Hatef Khadivinassab
hatef is on a distinguished road
Emma,
This is wrong!
regards,
hatef is offline   Reply With Quote
Old   July 10, 2013, 12:49
ddmillar is on a distinguished road
Hatef,
Care to elaborate on why this is wrong? I'm about to start writing a similar UDF and would greatly appreciate an explanation on why you think this is incorrect.
Cheers,
ddmillar is offline   Reply With Quote
Old   July 11, 2013, 06:19
Hatef Khadivinassab
Ddmillar,
Because in Emma's code, she has defined y (the temperature of the face) outside the loop, and inside the loop the value of y is overwritten by x[0]. Although this was really helpful, but unfortunately this does not work. I have written a code for time and temperature dependent heat transfer coefficient as follows;
#include "udf.h"
face_t f;
real y;
real t = CURRENT_TIME;
y = F_T(f,thread);
if (t<250)
F_PROFILE(f, thread, position) = 0.00000026*(y*y*y) - 0.00038*(y*y) + 0.25*y - 38;
else
F_PROFILE(f, thread, position) = 0.00000014*(y*y*y) - 0.00021*(y*y) + 0.14*y - 20;
Regards,
Old   January 4, 2015, 13:14
kaeran is on a distinguished road
Hello Hatef,
I have similar problem in defining HTC through UDF.
If I am not wrong, bulk temperature or reference temperature has to be also included in the program.
But I could see only a temperature polynomial equation is defined to get HTC.
Could you please expalin me, how did you arrive with this equation?
I am relatively new to UDF...So please help me out in understanding the UDF written by you.
kaeran is offline   Reply With Quote
Old   April 7, 2015, 10:27
Default Want to write UDF for heat flux on wall for a cylindrical tube change with temperatur
Geetesh Waghela
geeteshwaghela1234 is on a distinguished road
hey guys,
I am doing analysis on a cylinder with 2D axisymmetric model in fluent.
I have implemented a profile file for outer wall of cylinder but i want to implement a udf for inner wall as a function of temperature so that i could get accurate temperature on axis(fluid region).
my axial length is 0.1m and longitudnal length is 0.003m from axis.
I have tried using constant heat flux and coupled condition on inner wall but it does not help.
i want to get temperature profile in fluid region.
geeteshwaghela1234 is offline   Reply With Quote
Old   April 7, 2015, 18:52
`e`
`e` is on a distinguished road
Why not let Fluent use the energy equation to simulate the temperature profile on the inner wall?
`e` is offline   Reply With Quote
Old   April 7, 2015, 23:16
Geetesh Waghela
Hey e,
I have outer wall temperature profile from experiment using methane-air as fluid entering into the geometry.
I made the temperature profile as boundary condition on outer wall using profile.
If i let the inner wall as coupled then axis nor the inner wall does not get sufficient temperature as it should get. the material i use is fused silica for cylinder.
If i choose inner wall as heat flux and i gave it as zero then inner wall receives proper temperature but axis remains at 300 K.
According to the results my inner wall and axis both should have a temperature of 1300 K but i am getting till 800 K only at the place of highest temperature.
What should i do?
Old   May 16, 2016, 14:04
Default UDF wall heat flux
  #13
Narender Kumar
ykumarnarender is on a distinguished road
Hello everyone, i am simulating turbulent flow in a rectangular duct with heat flux from one side wall (bottom). I want the heat flux vary axially (as a function of axial distance). Does anyone have any idea about how it can be done ?
ykumarnarender is offline   Reply With Quote
Old   September 15, 2016, 11:52
hussein
hussein92 is on a distinguished road
please help how can i define the heat flux as a function of temperature of wall q=1000*(1-0.014*(T-298)) any one can help me in writing the UDF please
hussein92 is offline   Reply With Quote
Old   July 12, 2017, 07:25
AnsysUser
Shreman is on a distinguished road
#include "udf.h"
face_t f;
y = x[0];
where ¨F_PROFILE(f, thread, position) = 0.7942 + 1.3915*log(y);¨ this equation comes from?
Shreman is offline   Reply With Quote
Old   July 15, 2017, 05:45
Saurav Chakraborty
srv1406 is on a distinguished road
hello Hussein, please let me know if you got your UDF working for the temperature dependent heat flux. I am also trying for the same, not yet successful. It seems the DEFINE_PROFILE macro is not sufficient. I was suggested that the DEFINE_EXECUTE_AT_END macro is also required, but i am not able to put it up together.
Any help from a senior member would also be highly appreciated.
srv1406 is offline   Reply With Quote
Old   July 15, 2017, 06:54
Saurav Chakraborty
Thanks to Hatef. The one written by him in the thread above works perfectly well.
Old   August 5, 2018, 04:31
gouravjee is on a distinguished road
vprofile.c
#include "udf.h"
real y;
face_t f;
y = x[1];
I have to calculate heat transfer losses from radial surface of the cylinder.
I have written a udf for this but it is showing "segmentation fault".
can you tell me where might be the problem ?
#include "udf.h"
DEFINE_PROFILE(fluxloss,thread,position)
real h;
real T_ext;
face_t f;
begin_f_loop(f,thread)
h = 10;
T_ext = 300;
F_PROFILE(f,thread,position) =-10*(WALL_TEMP_INNER(f,thread)-T_ext);
end_f_loop(f,thread)
gouravjee is offline   Reply With Quote
Old   August 7, 2018, 03:44
pakk will become famous soon enough
Gouravjee, you don't need to ask the same question so many times on different locations on this forum... One time is enough!
pakk is offline   Reply With Quote
heat transfer coefficient, udf
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Wall Transfer Coefficien - Heat Transfer Coefficient - CFX Gargioni CFX 12 September 23, 2019 16:09
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
