May 15, 2012, 05:41 |
UDF code(ask for help)
zhuoweili
Rep Power: 14 |
I am struggled with UDF, now I suppose to define the inlet velocity as below, but the code has some error, could you please help me out and check what is wrong about my code?
I appreciate it. the equation is as below: V(x,y,t)=15.2*((2*x/0.00625)^8-1)+0.076*sin(0.8*pi*t)+0.076*sin(6*y/0.00625) #include "udf.h" DEFINE_PROFILE(velocity_profile,t,i) { int ts; real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; ts = N_TIME; /*you can calculate real time from time step obtained here*/ begin_f_loop(f,t) { F_CENTROID(pos,f,t); x = pos[0]; y = pos[1]; F_PROFILE(f,t,i) =-{1-(2*x/0.00625)^8 }*15.2+0.076*sin(0.8*π*t)+0.076*sin(6*y/0.00625); } end_f_loop(f,t) } |
May 15, 2012, 09:43 |
Daniel Tanner
Rep Power: 18 |
There are some mistakes here:
Where is pos specified? Try this and let me know how it works. real pos[ND_ND]; /* this will hold the position vector */ real x,y; Always run these over multiple time steps (even without converging) to ensure that the boundary condition is behaving as you intend. The N_TIME macro only returns the current time step in you case it may be worth considering CURRENT_TIME instead (time independent to the time-step size), see: http://hpce.iitm.ac.in/website/Manua...df/node105.htm Last edited by Daniel Tanner; May 15, 2012 at 09:48. Reason: More information |
May 15, 2012, 11:20 |
Laurent B
Rep Power: 16 |
replace t by ts in the velocity profile function (t is the thread)
May 21, 2012, 11:04 |
zhuoweili
Rep Power: 14 |
Hi there,
Thank you for your note. I fixed my code, but it is still not working for me...I got mad...Please help me out. The code is as below: #include "udf.h" DEFINE_PROFILE(unsteady_velocity,thread,index) { real x [ND_ND]; face_t f; begin_f_loop(f, f_thread) { F_CENTROID (x, f, t); x=pos[1]; real t=RP_Get_Real("flow time"); F_PROFILE(f,thread,position) =-(1-(2*x/0.00625)^8)*15.2+0.076*sin(0.8*3.1415926*t); } end_f_loop(f, f_thread) } |
May 21, 2012, 11:05 |
zhuoweili
Rep Power: 14 |
Error: D:\\Tem/udf.h: line 4: parse error.
cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/udfconfig-node0.h>" "C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/New Text Document (3).c.0.c" Error: C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/New Text Document (3).c.0.c: line 7: f_thread: undeclared variable |
May 22, 2012, 01:47 |
Laurent B
Rep Power: 16 |
The code with no compilation error :
#include "udf.h" DEFINE_PROFILE(unsteady_velocity,thread,index) { real pos [ND_ND]; real x, t; face_t f; begin_f_loop(f, thread) { F_CENTROID (pos, f, thread); x=pos[1]; t=RP_Get_Real("flow time"); F_PROFILE(f,thread,index) =-(1-pow(2*x/0.00625,8))*15.2+0.076*sin(0.8*3.1415926*t); } end_f_loop(f, thread) } |
May 22, 2012, 03:47 |
zhuoweili
Rep Power: 14 |
Hi, I tried your revised code, I supposed to read it in FLUENT, but I still got error, I don`t know why. What should I do when I hook this code with FLUENT?
p.s. Can we talk on skype? pps. I am using Ansys 14.0, do you think the version of FLUENT is the problem? ppps. Is there any space here (pos, f, thread);?(f, thread)? (pos,f,thread);?(f,thread)? Which one is correct? I am looking forward to your reply. Kind regards |
May 22, 2012, 04:17 |
Daniel Tanner
Rep Power: 18 |
It looks like you have extra spaces this might be the problem:
Try changing these! real pos [ND_ND]; => real pos[ND_ND]; F_CENTROID (pos, f, thread); => F_CENTROID(pos, f, thread); |
May 22, 2012, 04:21 |
#9 |
zhuoweili
Rep Power: 14 |
Hi, thank you both of you.
I still got an error which is attached below...What does it mean? cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<udfconfig-host.h>" "D:\Tem\u.c" cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/udfconfig-node0.h>" "C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/u.c.0.c" |
May 22, 2012, 04:40 |
#10 |
Laurent B
Rep Power: 16 |
I don't have any errors. This is the compilation commands.
May 22, 2012, 05:28 |
#11 |
Daniel Tanner
Rep Power: 18 |
As laurentb says the output you have included does not mention either warnings or errors. Is this all of the message? It may well have compiled correctly.
May 22, 2012, 05:50 |
What should I do?
#12 |
zhuoweili
Rep Power: 14 |
mmmmm...
Thanks alot. but I don`t know why I could not read it in FLUENT. first, I saved it as .c file second, in FLUENT I used define-user defined-functions-interpreted and then I got this cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/udfconfig-node0.h>" "C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/u.c.0.c" |
May 22, 2012, 06:24 |
#13 |
Daniel Tanner
Rep Power: 18 |
The message you showed is not an error! This is just the compilation sequence. This was fine for me but had problems when I was applying it as a boundary condition.
I tried this and it seemed to work fine: #include "udf.h" DEFINE_PROFILE(unsteady_velocity,thread,index) { real pos[ND_ND]; real x, t; face_t f; begin_f_loop(f, thread) { F_CENTROID(pos, f, thread); x=pos[1]; t=CURRENT_TIME; F_PROFILE(f,thread,index) =-(1-pow(2*x/0.00625,8))*15.2+0.076*sin(0.8*3.1415926*t); } end_f_loop(f, thread) } |
May 22, 2012, 06:35 |
#14 |
zhuoweili
Rep Power: 14 |
I tried this code, and I got new information... cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<udfconfig-host.h>" "D:\Tem\example.c" Error: D:\\Tem\\example.c: line 2: D:\\Tem\\example.c:1: `#include' expects "FILENAME" or <FILENAME> parse error. 999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 The Parallel FLUENT process could not be started. what should I do? |
May 22, 2012, 07:47 |
#15 |
Daniel Tanner
Rep Power: 18 |
You will have to debug this problem:
1) try it in serial (1 cpu) 2) try without the t=CURRENT_TIME; use t =0; instead. These will help to narrow down the problem. I'm not sure what happened earlier when you had problems, can you explain it further? the message "cpp -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/cortex/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/client/src" -I"C:\PROGRA~1\ANSYSI~1\v140\fluent\fluent14.0.0/multiport/src" -I. -DUDF ONFIG_H="<C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/udfconfig-node0.h>" "C:/DOCUME~1/lzhuowei/LOCALS~1/Temp/u.c.0.c"" seems fine to me (not an error, just normal output). Did you have problems when you hooked it as a boundary condition or where did the error occur? |
May 22, 2012, 08:53 |
#16 | |
zhuoweili
Rep Power: 14 |
Hi, I appreciate both of you. Finally the code is working properly. I am using serial instead of parallel, and also I read the udf in case rather than data and case. So it works now. It seems that there is no problem with the code. It is hooked with FLUENT, I could read this velocity in boundary condition. Please keep contacting with me, I hope you can help me again in the near future, I am a beginner of UDF, I need you kind regards zhuowei Last edited by Jo_vivian_lee; May 22, 2012 at 09:33. |
May 22, 2012, 09:33 |
#17 |
zhuoweili
Rep Power: 14 |
Now I am trying to plot the velocity profile in FLUENT, this work will be done if I can see a sinusoidal curve the same as what the math function describes, thanks a lot. Unfortunately, I couldn't see the sine curve...oh my god... May I ask that how can I plot the velocity changing with time? Usually I just can plot the velocity changing with position… kind regards zhuowei |
May 22, 2012, 10:01 |
#18 |
Daniel Tanner
Rep Power: 18 |
You can set up a monitor at the inlet. Set it as the area weighted average velocity or just display the volume flow rate and see how it changes as time progresses (display as time-step not iteration).
For this you don't need a converged solution you just want to check what condition you have applied at the boundary so one iteration per time step is fine. |
May 22, 2012, 10:35 |
#19 | |
zhuoweili
Rep Power: 14 |
Thank you for your note. I did what you told me, but I got a message that "cx-xy-plot-files: No data points in range." I used auto range. I look forward to your reply. Many thanks Zhuowei |
May 23, 2012, 08:02 |
#20 |
zhuoweili
Rep Power: 14 |
Hi, I got another problem.
I have had the code, and it also could be read into FLUENT. Now I want to verify it in C++, I want to see the sin curve in c++, but unfortunately, in c++ I got some errors as below:what is the problem? How can I fix them? the system cannot find the path specified 1>------ Build started: Project: 01, Configuration: Debug Win32 ------ 1>Compiling... 1>01.cpp 1>d:\tem\01\01\01.cpp(6) : error C2065: 'cout' : undeclared identifier 1>d:\tem\01\01\01.cpp(6) : error C2065: 'endl' : undeclared identifier 1>Build log was saved at "file://d:\Tem\01\01\Debug\BuildLog.htm" 1>01 - 2 error(s), 0 warning(s) ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ========== |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
