July 28, 2012, 23:47 |
UDF slip and temperature jump from IFRT
Tajul
I am simulating rectangular channel flow with slip velocity and temperature jump. UDF I used from IFRT report. My problem is as below: UDF for slip velocity Hooking UDF is ok. After hooking whenever I impose slip velocity on wall then it shows the following error: Error: rpgetvar: coordeval: undefined variable Error: Object: () UDF for Temperature Jump For temperature jump condition hooking is not successful: it shows Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () error: Is there anybody to solve this. I need it very much. I appreciate any kind of help. Thank in advance. Abir tajul000@yahoo.com |
July 30, 2012, 05:44 |
Alex
Rep Power: 47 |
Do you want to share the UDF you used?
How can I implement temperature jump boundary condition in microchannel walls? | sima | FLUENT | 7 | January 6, 2021 21:36 |
How to set slip velocity and temperature jump | awuunity | CFX | 10 | July 2, 2018 08:40 |
Implementation of maxwell slip velocity and Temperature jump with openfoam | yassepid | OpenFOAM | 2 | June 28, 2016 07:05 |
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. | dayashankar | FLUENT | 1 | May 18, 2016 21:45 |
