UDF for writing porosity as a function of distance from the wall
Old   August 1, 2012, 12:10
Default UDF for writing porosity as a function of distance from the wall
Rohini Bala Chandran
rohinibc is on a distinguished road
I am unable to get my UDF for setting porosity variation to work out. Here is what my fn.c code looks like.
UDF to specifiy porosity as a function of distance from the wall of the packed bed reactor
#include "udf.h"
#define H 0.1
#define dp 0.008
DEFINE_PROFILE(porosity_function,t,i)
cell_t c;
real x[ND_ND]; /*This will hold the position vectors*/
real y;
real a1;
real a2=6; /*to specifiy the porosity variation function*/
real eps_inf=0.37;
real eps;
a1 = (1./eps_inf)-1;
begin_c_loop(c,t)
C_CENTROID(x,c,t);
y = (H - x[1])/ dp ;
eps = eps_inf*(1. + a1*exp(-1*a2*y));
F_PROFILE(c,t,i) = eps;
end_c_loop(c,t)
I tried using both F_PROFILE and C_PROFILE inside the code. The code builds and loads alright during compilation. But when I try to use in in the porous zone as function for porosity, it doesn't work. It gives me an error which is :
Error = invalid argument; not a number[1]
Could anybody help me with this?
rohinibc is offline   Reply With Quote
Old   August 6, 2012, 02:05
gearboy is on a distinguished road
use the following code to specify cell profile. It seems your error is led by other problems.
begin_c_loop(c,t)
F_PROFILE(c,t,i)=......;
end_c_loop(c,t)
Originally Posted by rohinibc View Post
#include "udf.h"
#define H 0.1
#define dp 0.008
cell_t c;
real y;
real a1;
real eps_inf=0.37;
real eps;
begin_c_loop(c,t)
C_CENTROID(x,c,t);
end_c_loop(c,t)
gearboy is offline   Reply With Quote
Old   August 7, 2012, 17:06
Default @gearboy
hey,
Thanks for responding. But then, I am still unable to figure out what you are actually saying. I did put in F_PROFILE(c,t,i) in my code. and, its still giving me the same error. Am I not catching something you are saying correctly?
thanks,
Old   August 7, 2012, 22:05
hey,
thanks,
I think there might be a math error in your computation. Try printing the "eps" for each cell.
#include "udf.h"
#define H 0.1
#define dp 0.008
cell_t c;
real y;
real a1;
real eps_inf=0.37;
real eps;
begin_c_loop(c,t)
C_CENTROID(x,c,t);
Message("%g\n",eps); // monitor each cell's eps
end_c_loop(c,t)
Old   August 8, 2012, 05:04
zainab
zainab is on a distinguished road
Hi gearboy
i working on modeling 3D gas-liquid slug flow in horizontal pipe with fluent, but I can not get the true phase distribution for the fluids, I think that I need to use a volume fraction UDF can you help me the following UDF for profile of velocity, how can I change it to get one for VF where I wont to set lower half of the cylindrical pipe to 1 means filled with secondary phase while the upper half being take its values from the normal iterations from the mixture velocity and other initial and boundary conditions. I need UDF constant with time not like the below which is time dependent.
Thank you.
DEFINE_PROFILE(VOLUMEFRACTION_profile, t, nv )
face_t f;
real x[ND_ND];
real f_time = RP_Get_Real("flow-time")
begin_f_loop (f,t)
F_CENTROID(x,f,t);
if (f_time<=10e-1)
{F_PROFILE(f,t,nv) = 1*cos(PI*f_time/3);
else
F_PROFILE(f,t,nv) = 0;
end_f_loop (f,t)
zainab is offline   Reply With Quote
Old   August 8, 2012, 08:16
Default checked printing cells
Hi gearboy,
I checked printing out my porosity values outside of this udf function as a regular c function and it seems to be fine. There is no case where NaN comes up when I evaluate this function.
define_profile, porosity, udf
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
