the macro DEFINE_MASS_TRANSFER can't use as compile udf in ansys14.0
Like Tree3Likes
  • 1 Post By sooroo3
  • 2 Post By hane
Old   August 27, 2012, 10:31
Cool the macro DEFINE_MASS_TRANSFER can't use as compile udf in ansys14.0
Fangdian
fangdian is on a distinguished road
hi,
These days, I use the macro DEFINE_MASS_TRANSFER in the ansys14.0, I found that this macro can't be correctly used as compiling UDF.
In the C source file, i define two macros: one is the DEFINE_PROPERTY to set the material properties and the other is the DEFINE_MASS_TRANSFER to set the mass tranfer between two phases.
#include "udf.h"
DEFINE_PROPERTY(cell_vis,cell,thread) /*定义材料粘度*/
{real ga_visy;
real temp=C_T(cell,thread);
if(temp<=1773)
ga_visy=2;
else if(temp<=1853)
ga_visy=1e-3*(119.003-0.061*temp);
else if(temp<=1873)
ga_visy=1e-3*(10.603-0.0025*temp);
else if(temp<=1973)
ga_visy=1e-3*(36.263-0.0162*temp);
else
ga_visy=3e-3;
return ga_visy;
DEFINE_MASS_TRANSFER(liq_gas_source,cell,thread,fr om_index,from_species_index,to_index,to_species_in dex)
real m_lg;
real T_frost=1773;
Thread *liq = THREAD_SUB_THREAD(thread, from_index);
Thread *soild = THREAD_SUB_THREAD(thread, to_index);
m_lg = 0.;
if (C_T(cell, soild) >= T_frost)
m_lg = -0.1*C_VOF(cell,soild)*C_R(cell,soild)*fabs(C_T(cel l,soild)-T_frost)/T_frost;
if ((m_lg == 0. ) && (C_T(cell, liq) <= T_frost))
m_lg = 0.1*C_VOF(cell,liq)*C_R(cell,liq)*fabs(T_frost-C_T(cell,liq))/T_frost;
return (m_lg);
I compile the C source file and load them success which can be verified by the messages in the message window:
Done.
Copied F:\rongdi\seconddimension/F:\rongdi\seconddimension est.c to libudf\src
Copied F:\rongdi\seconddimension/F:\rongdi\seconddimension\udf.h to libudf\src
(system "copy "E:\softwear\special\ansys14\ANSYSI~1\v140\fluent" \fluent14.0.0\src\makefile_nt.udf "libudf\ntx86\2ddp\makefile" "
(chdir "libudf"()
(chdir "ntx86\2ddp"()
# Generating ud_io1.h
test.c
# Generating udf_names.c because of makefile test.obj
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj test.obj
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation. All rights reserved.
Done.
Opening library "F:\rongdi\seconddimension\libudf"...
Library "F:\rongdi\seconddimension\libudf\ntx86\2ddp\libud f.dll" opened
cell_vis
liq_gas_source
Done.
Subsequently, I can use the cell_vis to chang the material property, but when i use the function "liq_gas_source" in the phase interaction window, I can't find the function and an error was found as follows:
Error:No user-defined functions have been loaded.
Error Object:#f
IF i use the marco DEFINE_MASS_TRANSFER as interpreted UDF, it is OK.
On the other hands, i can successly use this marco in the ansys12.0 as compile UDF.
That is to say, I can't use the marco as compile UDF in the ansys 14.0 but only the interpreted UDF.
Is the version problem??Or there is a defect in the ansys14.0 ?
ps: My case file, mesh file and C source file is attached in the attachments.
File Type: c test.c (914 Bytes, 27 views)
fangdian is offline   Reply With Quote
Old   September 4, 2012, 02:31
lzc
jajun is on a distinguished road
I have the same problem. I am searching for a solution.
jajun is offline   Reply With Quote
Old   September 4, 2012, 21:30
Fangdian
jajun:
Do you use the compile UDF? It is well if you use the Interpreting UDF. I think it is probalely solved by the mixture UDF?
Old   September 5, 2012, 10:02
Tenglong Cong
softice2006 is on a distinguished road
Originally Posted by fangdian View Post
jajun:
Is mixture UDF available in ANSYS FLUENT 14? Do you find a solution?
If there are any solutions, please send me a message, thank you!
softice2006 is offline   Reply With Quote
Old   September 6, 2012, 01:49
lzc
jajun:
When I interpreted the UDF, after initialization, there are errors as "mpi_error=10054". And I don't know how to solve it.
Old   September 6, 2012, 06:58
Wink
Fangdian
Are there other UDFs beside the DEFINE_MASS_TRANSFER? Sometimes there are the UDFs which can't be used with the interpreting measure.
When I use the macro DEFINE_MASS_TRANSFER with interpreting way, there is only one DEFINE_PROPERTY macro except the macro DEFINE_MASS_TRANSFER.
psid you use the parallel UDF with Windows system?
As far as the error_10054, perhaps there are many reasons.You could search the possible answer on the internet. for example:
http://cape-forum.com/index.php?topic=1283.0
Good luck to you!
Old   September 6, 2012, 07:01
Arrow
Fangdian
softice2006:
Sorry! I have not get the solutions with the mixture UDF. I will send you a message if i get the solution.
Best Wishes!
Old   September 11, 2012, 12:07
lzc
softice2006:
Best Wishes!
Another way to the problem was identified a mass source and energy source, and it'll work well too.
Old   September 25, 2012, 02:33
Fangdian
dear jajun:
Thank you for your reply!I will try it out.
Old   November 26, 2012, 09:12
YG Kim
sooroo3 is on a distinguished road
Did you succeed it? I try to implement UDF mass transfer by use of phase interaction tab, but I fail to run the calculation. How you can access the phase level temperature “C_T(cell, soild)”? I use VOF model that solves mixture level enthalpy equation instead of temperature type energy equation. In this sence, I couldn’t understand phase level temperature macro (C_T(cell, solid). Is there some physics I didn’t catch yet? Thank you.
sooroo3 is offline   Reply With Quote
Old   February 14, 2013, 08:35
SSL
msaeedsadeghi is on a distinguished road
I have asked Ansys Fluent support team. The problem is with the cracked version of fluent. In licensed version it can be easily be selected in interaction menu.
msaeedsadeghi is offline   Reply With Quote
Old   November 22, 2013, 03:50
mehdimoradi
mehdimoradi. is on a distinguished road
Hi;
Could you access the phase level temperature? because i want to interpret a mass transfer udf but have a difficulty in definition of phase temperature. if you solved your problem anyway let me know kindly.
thanks
mehdimoradi. is offline   Reply With Quote
Old   November 22, 2013, 06:36
YG Kim
Mehdimoradi;
If VOF model is employed, there may be no way to access the phase level temperature because a enthalpy equation is solved for mixture level energy. Under one field assumption in multiphase flow, VOF method, usually, solves single set of Navier stokes as well as energy equation for two phase.
6863523 likes this.
Old   August 23, 2014, 10:00
Default hamed.moradkhani@yahoo.com
  #14
sarighulikhan
hane is on a distinguished road
do the following and keep me inform about the results
+ first write case file and data file
then hook the compiled udf
1.define->user-defined->functions->interprated..
interprate the q.c file
2.type on the command window of fluent
solve(press enter)
set(press enter)
expert(press enter)
answer for the 4 comming questions respectively are:
no-yes-no-yes
after these 2 steps u can hook the udf from phase intraction->mass tab->user defined->selecting udf...
now you can start runing calculation
6863523 and yiouyang2020 like this.
hane is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
