UDF F_PROFILE problem
Old   September 4, 2012, 04:35
Default UDF F_PROFILE problem
Zhi-Gang Zhai
zgzhai is on a distinguished road
Hello everyone!
These days I meet a fluent udf problem. I want to use the F_PROFILE to set the inlet velocity, but the result is not OK.
My case information is as follows. 2D , R-Z coordinate, the horizontal directoin is the Z axis, the vertical direction is the R axis. I use the k-e model. Calculate the energy equation.
I set the inlet axial velocity to -0.2m/s as and the radial velocity to 0m/s in the fluent GUI. The result is OK.
But I use the udf (DEFINE_PROFILE) to set the inlet velocity. The result is not OK. The velocity is very very low, almost stop.
DEFINE_PROFILE(axial_vel, t_face, i)
face_t f;
begin_f_loop(f, t_face)
F_PROFILE(f,t_face,i) = -0.2;
end_f_loop(f, t_face)
Pls look the following result figures. Who could tell me the probable reason. Thank you very much in advance.
1. set the inlet velocity to constant in the fluent GUI.
http://www.facebook.com/photo.php?fb...type=1&theater
2. use the udf to set the inlet velocity
http://www.facebook.com/zhigang.zhai...type=1&theater
zgzhai is offline   Reply With Quote
Old   September 5, 2012, 05:09
Default I find the some reason
Zhi-Gang Zhai
Hello, everyone.
The above problem, I use the 'interpreted' mode to run it, the result is OK.
But the 'compiled' mode is not OK, I don't know why?
Old   September 5, 2012, 07:21
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
So, the problem is with your compiler. You have not installed compiler correctly or it has not been linked to fluent.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   September 5, 2012, 12:06
Zhi-Gang Zhai
Thanks to eng_s_sadeghi , I guess you are right, My OS is win7, but my c compiler is old one, which i copy from the winXP. So maybe it is not compatible. Thank you!
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
