how to set up and write a cosine UDF
Like Tree3Likes
  • 2 Post By ghost82
  • 1 Post By ghost82
Old   September 19, 2012, 10:16
Default how to set up and write a cosine UDF
Chris K
chriskit is on a distinguished road
Hello everybody,
i ve got a problem with my inlet boundary conditions. i want to implement a cosine (or sine) function because, i got a pulsative flow at the inlet. my flow changes every second from 0 to 20 m/s.
one possible function would be 10*cos(x*pi)+10 with 0<x<2.
Now, i just dont know how to setup this function in fluent and how and where to wirte it. I know that i have to define this function somewhere and upload it after in fluent. and how can i tell fluent that one period is like 4 seconds?
Would be really great if someone can help me with this.
regards, chris
chriskit is offline   Reply With Quote
Old   September 19, 2012, 12:47
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
You should read the Fluent UDF manual here:
http://hpce.iitm.ac.in/website/Manua...f/main_pre.htm
Alternatively you can create a Profile file with discrete velocity vs. time data and use that. See here:
http://hpce.iitm.ac.in/website/Manua...ug/node301.htm
NormalVector is offline   Reply With Quote
Old   September 20, 2012, 08:02
Chris K
ok thanks i`ll try it!
Old   September 20, 2012, 11:22
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Originally Posted by chriskit View Post
Hello everybody,
regards, chris
I don't understand very well: your function should be time dependent but there isn't time in your function..what is x?time?
From what I understand I think you want to change velocity at inlet with a time dependent cos function.
If so, try this udf.
#include "udf.h"
#include "math.h"
#include "mem.h"
DEFINE_PROFILE(my_velocity, thread, position)
  face_t f;
  real t = CURRENT_TIME;
  begin_f_loop(f, thread)
          F_PROFILE(f, thread, position) = 10.*cos(t*3.14159)+10.;
  end_f_loop(f, thread)
Am I right?
If so copy this udf in a textedit file and save it as somename.c (not txt extension but c extension) and put it in the folder of your cas and dat files.
Open fluent and go to define->user-defined->functions->interpreted.
Choose the c file and interpret it.
Then in your velocity boundary condition choose your interpreted udf ("my_velocity").
Choose an appropriate time step for your unsteady simulation and stop it after some periods (you know 1 period is 2 seconds).
Also, I don't understand this:
..and how can i tell fluent that one period is like 4 seconds?
your period is 2 seconds not 4.
If I don't understand post a sketch of your domain and explain better.
Daniele
Far and Chong070940103 like this.
ghost82 is offline   Reply With Quote
Old   September 21, 2012, 06:08
Chris K
Hey Daniele,
thanks a lot! You understood it absolute right. And really thanks for the code, my knowledge at C and C++ isnīt that big...
So now, i made it like your proposal but the new problem is that "my_velocity" doesn`t appear at the boundary conditions. I think interpreting worked well but i can`t choose this condition.
Do you know what kind of problem could be the reason for that?
Thank you and regards,
chris
Old   September 21, 2012, 06:28
ghost82's Avatar
Rick
Hey Daniele,
chris
Hi Chris,
after interpreting your udf, go to boundary condition panel, choose your inlet, then change from "constant" to udf my_velocity.
PS: if you start your simulation with your function velocity at time=0 s is 20 m/s; you should perform a steady state simulation first, with v=constant=20 m/s than switch to unsteady and apply your cosine udf.
Daniele
Far likes this.
Old   September 21, 2012, 09:38
Chris K
ok great, thank you, now it works!!!
