lagrange gun UDF
Old   January 16, 2013, 00:04
Default lagrange gun UDF
mehdi
aydinkabir88 is on a distinguished road
I want to simulate a piston which move on the differential pressure force acting on its two surfaces.
The UDF tha I use is:
* 1-degree of freedom equation of motion (x-direction)
* compiled UDF
#include "udf.h"
static real v_prev = 0.0;
DEFINE_CG_MOTION(piston,dt,vel,omega,time,dtime)
Thread *t;
face_t f;
real NV_VEC(A);
real force, dv;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
force = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force += F_P(f,t) * NV_MAG(A);
end_f_loop(f,t)
/* compute change in velocity, i.e., dv = F * dt / mass
velocity update using explicit Euler formula */
dv = dtime * force / 50.0;
v_prev += dv;
Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev,
force);
/* set x-component of velocity */
vel[0] = v_prev;
But it doesn't work. would you please help me?
thanks.
aydinkabir88 is offline   Reply With Quote
Old   January 21, 2013, 08:42
Marion
Marion is on a distinguished road
Why don't you use the "Compute_Force_And_Moment" function for the calculation of the force?
I've seen it in the 6DOF examples of the tutorials.
Marion.
Marion is offline   Reply With Quote
Old   January 22, 2013, 08:40
Syavash Asgari
syavash is on a distinguished road
Originally Posted by Marion View Post
Marion.
Dear Marion,
What tutorial exactly do you refer?! I can't find it among Fluent tutorials. If you'd have such tutorial would you please send it to me?! Me E-mail is
syavash_azna@yahoo.com
Thank you
syavash is offline   Reply With Quote
Old   January 23, 2013, 00:05
mehdi
Marion.
Dear Marion
Would you please send me that axample?
aydinkabir88@gmail.com
thanks in advance.
Old   January 23, 2013, 14:32
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Originally Posted by aydinkabir88 View Post
Dear Marion
thanks in advance.
Hi, I think you can refer to tutorial 'Projectile Moving Inside a Barrel'; search the pdf on google.
This is the same approach I proposed to you in private message.
Daniele
ghost82 is offline   Reply With Quote
Old   August 9, 2014, 00:34
arash
shayegan is on a distinguished road
Hi everyone
I have been working on moving projectile in a barrel. I need udf for dynamic mesh(Six degree of freedom solver). can anyone help me?
shayegan is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
