Problem in using UDF in parallel computing
Old   January 22, 2013, 08:23
Default Problem in using UDF in parallel computing
Yogini Patel
Yogini is on a distinguished road
I made an UDF for steam properties calculation. In serial case (single CPU) it works well. But I would like to use this UDF file in parallel computing in linux cluster with 4 nodes.
I have tried to read many threads about this issue online and also UDF manual but I am not able to understand it.
Here I attach my UDF file.
Can anyone give me any suggestion regarding this problem ?
I really appreciate any kind of help in this issue
Thank you in advanced !!
With regards,
Yogini
Yogini is offline   Reply With Quote
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
Parallel UDF problem, hello world version pilou FLUENT 0 March 10, 2011 08:20
problem to make a UDF parallel, the "hello world version" pilou Fluent UDF and Scheme Programming 0 March 10, 2011 08:19
problem to make a UDF parallel pilou Fluent UDF and Scheme Programming 0 March 9, 2011 06:35
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
