Error: rpgetvar: coordeval: undefined variable
Old   February 22, 2013, 23:17
Default Error: rpgetvar: coordeval: undefined variable
Tajul
abir is on a distinguished road
Hi
why UDF containing the following line
if (RP_Get_Integer("coordeval")==1) {
coord_coeff(f_thread);}
gives
What is the solution? I"ll be gratefull if anyone can help.
Thanks in advance.
Abir
abir is offline   Reply With Quote
Old   February 23, 2013, 02:07
SSL
msaeedsadeghi is on a distinguished road
Because the variable input should be set using GUI. You should make a GUI, else should set it manually in the UDF and delete rpgetvar.
msaeedsadeghi is offline   Reply With Quote
Old   February 23, 2013, 07:02
Tajul
Hi
Thanks a lot for your quick response. I could not follow you. "coordeval" is a scheme variable. But value of coordeval is not known. Have I to put in the following way in UDF of Fluent?
#define coordeval value
If possible Please explain in detail. Have a nice time.
Abir
Old   February 23, 2013, 07:31
SSL
Use 1 for coord_c... to enable it.
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
