read parameters into UDF
Like Tree1Likes
  • 1 Post By coglione
Old   April 17, 2013, 10:38
Default read parameters into UDF
Michal Vonka
vonkam is on a distinguished road
Hello everybody,
does anybody has ideas about filling a UDF at start of simulation with parameters, so I don't have to rebuild the library when I change a parameter in UDF?
Thanks
Michal
vonkam is offline   Reply With Quote
Old   April 18, 2013, 02:38
Paritosh Vasava
vasava will become famous soon enough
Questions:
1. Do you mean that you want to write a UDF that modifies by itself?
2. Are you writing these UDF(s) for transient or steady-state simulations?
vasava is offline   Reply With Quote
Old   April 18, 2013, 03:20
Michal Vonka
ad 1) My original idea was to load a file of parameters into UDMemories, that would be used by all cells or any other way to stuff the UDF without need to changing it. That would require a new compilation, i guess.
ad 2) Ideally both, but that also depends on the demands on memory. I think I can live with steady state simulation only.
Thanks for any help.
Old   April 19, 2013, 03:26
Max
coglione is on a distinguished road
Have a look at the UDF-Manual ->Scheme Macros. I think that's what you need.
cheers
vonkam likes this.
coglione is offline   Reply With Quote
Old   April 19, 2013, 16:00
Default UDF Parameters
Bill Wangard
billwangard is on a distinguished road
The way to do this is to define an rpvar. Once created in the CASE, rpvars are saved with the case file.
Rpvars are variables that can be passed to the UDF routines. Thus, you can easily modify the UDF without recompiling. Rpvars can be changed from the FLUENT GUI panel using simple scheme commands.
Look in the UDF manual on how to do this. If you need an example, please contact me directly:
bill.wangard@engrana.com
Regards,
Bill Wangard
Engrana LLC
billwangard is offline   Reply With Quote
How to Read a "Profile" format file in UDF? gary7 Fluent UDF and Scheme Programming 32 July 12, 2022 01:17
UDF Compiling - can't read ..\..\src\xxx_udf.c: No such file or directory willy Fluent UDF and Scheme Programming 0 March 28, 2013 11:22
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Read wall profile in UDF linhtst FLUENT 0 May 12, 2011 10:09
UDF - Read from files sega Fluent UDF and Scheme Programming 4 March 31, 2010 06:50
